Temp Gauge not working, runs rough at idle
Old Sep 4, 2002 | 05:45 AM
zgrimes's Avatar
New User
Default Temp Gauge not working, runs rough at idle
I have an 94' Accord EX, v/tec, 94k on the odometer. The temp gauge hardly works, and when it does, it registers wayyyy low. Also when your sitting at a red light, usually with the AC on, the engine bucks. Any suggestions????
Thanx!
Old Sep 4, 2002 | 06:10 AM
greensleeper's Avatar
Default Re: Temp Gauge not working, runs rough at idle (zgrimes)
flsuh your cooling system. get a new thermostat?
I doubt the gage is bad but it is possible. mine ALWAYS read at about 4 o'clock.
Old Sep 4, 2002 | 06:36 AM
smokin rubber's Avatar
Default Re: Temp Gauge not working, runs rough at idle (greensleeper)
do you mean eight, four would be pointed the wrong way.
Old Sep 4, 2002 | 06:37 AM
Accord94DX's Avatar
Default Re: Temp Gauge not working, runs rough at idle (smokin rubber)
mine always reads 4 o'clock also.
Old Sep 4, 2002 | 06:49 AM
we're talking 5th gens here....
Old Sep 4, 2002 | 06:56 AM
Martaigne's Avatar
4 o'clock here too.
Old Sep 4, 2002 | 07:05 AM
GimpyAccord's Avatar
Default Re: Temp Gauge not working, runs rough at idle (martaigne)
I briefly had a 5th gen coupe and it was 4 oclock as well, ... but any Accord I've driven if the temp was anymore than say 1/3 up SOMETHING was wrong. Hondas have GOT to be the most consistant cars in reguards to cooling.
Old Sep 4, 2002 | 07:37 AM
chotchkie's Avatar
i would definately say its your thermostat if it runs rough at idle, probably too cold to register on the guage. take your thermostat out and put it over flame...if it opens, it may still work. if not, then get a new one
Old Sep 4, 2002 | 07:38 AM
chotchkie's Avatar
Default Re: Temp Gauge not working, runs rough at idle (GimpyAccord)
actually i believe honda's have two settings on the thermostat, partially open and open, while most cars have just open. so while other cars go up and down because their thermostats are open or closed, honda's have much less fluctuation because the thermostat can be partially open (i believe)
baherron
Sep 12, 2018 08:20 AM
therest
Mar 15, 2016 05:26 AM
bobryan
Dec 29, 2008 05:21 AM
danteisme
Feb 20, 2006 06:01 PM
Hondaman56
Feb 13, 2004 04:03 PM
