Jacking Car . . . Bang! Fans Falling Out!!!!
Old Sep 4, 2002 | 05:11 AM
90H22's Avatar
Default Jacking Car . . . Bang! Fans Falling Out!!!!
So I'm jacking my car thinking I'm using a good jack point seeing as how all my tires are flat and I can't see under there. Next there I know something creeks and pops and my fans are sticking up really high. I lower it back down and now they are sagging and all loose!!!! What in the hell did I break?
Old Sep 4, 2002 | 05:31 AM
greensleeper's Avatar
Default Re: Jacking Car . . . Bang! Fans Falling Out!!!! (Two1Accord)
you broke your fans.
Old Sep 4, 2002 | 05:41 AM
90H22's Avatar
Default Re: Jacking Car . . . Bang! Fans Falling Out!!!! (greensleeper)
So . . . what? I broke the casing they are in or something? How much are those to replace and do they come with H22 swaps? Seeing as how I'm about to order one that wouldn't be bad but I doubt it.
Old Sep 4, 2002 | 05:50 AM
Accord94DX's Avatar
might have broken a radiator support or something. Id take a good look around before getting parts.
No, they dont come with an h22.
Old Sep 4, 2002 | 05:54 AM
How the **** is anyone here suppose to know. You're jacking up your car. Crack. Fans sticking up.... way too vague man come on....
Sounds like you just cracked the housings. but it could be more damage.. possibly to the fan blades, could have bent the motor shaft. There's AC lines, and a raditor line right there that could have gotten hit. The front motor mount is like hlaf an ich away from the fans (at least on my 5th gen). Wire cold have been riped out. You could have bent you header pipe. Stick your head in the engine bay and look!!!
None of that stuff comes with the H22 swap but fixing it will be ten times easier if your swaping the motor out... simply because of accessability to the rear area of the radiator.
Go to the junk yard. Both the fans with the shrouds and everything couldn't cost more than 100 buck total. just a guess though.
Old Sep 4, 2002 | 05:57 AM
90H22's Avatar
Sorry about being so vague. I really can not get under the car and look. Looking from the engine bay everything looks perfectly fine. I'll go look and re-post. Thanks though.
Old Sep 4, 2002 | 06:09 AM
90H22's Avatar
After jacking the car from the side it seems I have used the bottom of my radiator as a jack point. Not good at all though I didn't bust any lines or anything. Just a radiator support I suppose.
Old Sep 4, 2002 | 06:20 AM
chotchkie's Avatar
how are all of your tires flat?!
Old Sep 4, 2002 | 06:45 AM
WuWarrior's Avatar
Where did you jack the car up from?? If you do it from the front, put the jack on the tow hook.
Old Sep 4, 2002 | 06:51 AM
John's Avatar
New User
You likely broke your lower radiator mount, maybe even your upper one... Assuming you were talking about your 2001 Accord, you can find the parts at #17 and #18 in this list: Click here
Old Sep 4, 2002 | 07:00 AM
90H22's Avatar
Default Re: Jacking Car . . . Bang! Fans Falling Out!!!! (DunReit For Sale)
Thanks for all the replies. No, it's not my 2001 but that does give me an idea about the price, can't be too much different. Thanks.
Oh, my tires are all flat because a while back I sort of destroyed my engine on the interstate and had to pull over quick because of heavy traffic. Both left tires got tore up while pulling off the road and the front right tire just went down on it's own for some reason.
This car has been sitting in my garage for about three months now so I just started doing some weight reduction in anticipation for my H22 I'm ordering next week.
Anyways, thanks.
Old Sep 4, 2002 | 08:19 AM
John's Avatar
New User
Well, go to http://www.hondaautomotiveparts.com and search around...
candyteggy
Sep 20, 2006 08:14 AM
Propulsion
May 15, 2006 02:43 PM
H22A_HB
Sep 16, 2004 11:00 PM
Jago
Sep 10, 2002 07:58 AM
