UPPER BUMPER SEALS
Old Jan 7, 2010 | 02:00 PM
mnmsddy's Avatar
Default UPPER BUMPER SEALS
HI ALL... I have a 90 civic HB DX... Any one know what these look like or what they are made of... I pulled my rear bumber, sealed a leak behind it in a body seam, put it all back together and have now tracked the leak to the mount holes... The online catalogs show "upper bumber seals" I had none installed... any thoughts
Old Jan 7, 2010 | 03:19 PM
Radim's Avatar
Default Re: UPPER BUMPER SEALS
If there is a harbor freight near you, they sell sheets of rubberish gasket material for cheap, you can make your own gasket.
Old Jan 7, 2010 | 03:23 PM
my91tealhb's Avatar
Got to your hardware store and just buy some rubber washers the same size as the mounting bolts. A little silicone wont hurt either.
Old Jan 7, 2010 | 05:51 PM
mnmsddy's Avatar
thanks guys, any idea on thickness, and do these seals go inside the hatch area, or between the bumber bracket and rear support. I can't tell from the picture.
Old Jan 7, 2010 | 08:11 PM
my91tealhb's Avatar
Put one on each side. One inside the hatch and outside on the body. Use a lttle silicone to adhere it to the body. Just use a flat rubber washer, should solve your problem.
Old Jan 8, 2010 | 06:21 AM
mnmsddy's Avatar
Thanks for the info... I'll head over to HD after work today. My goal is to be leak free so that I can put the interior back in, A lofty Goal I know, but a goal never the less.
user1122
Jun 11, 2015 04:44 AM
4serioferio
12
Jun 22, 2010 05:33 PM
vg7z
Aug 29, 2006 10:33 AM
bleedblue94
Jul 8, 2006 11:43 PM
omehegan
Nov 2, 2004 03:34 PM
