Question plz dont flame
Hey guys I have tried searching but no luck my searching skills r beat.
I would like to know what r my options for bigger front brakes and rear disc conversion?
Im pretty sure this has been covered over and over im sorry.
The rear discs will be purely an aesthetic mod. I went with bigger front brakes because I would experience brake fade when driving a bit hard. I used the Fasbrakes.com 11.1" kit that uses VW Corrado Rotors and Integra DC calipers. I love it.
fasbrakes.com does not work
is the corrado rotors a dc calipers pure plug and play no brackets needed?
is there a rotor and caliper combo from honda thats plug and play and is bigger than the original ef?
and even if the rear discs r just for aesthetics what is needed? (im function over form all day everyday with a hoodie on but if i could do the rear conversion for cheap y not)
Fastbrakes.com loaded up for me fine. It uses their bracket plus the parts I mentioned before. I used 2000 integra rear trailing arms and ebrake cables for my conversion. I re-used my EF toe arms and upper arms.
I did "upgrade" mostly for bling. I will only say that the bigger front brakes are better when I put the car through the same paces as before and see and actual difference
that is true, but its allways nice to have a greater surface area for friction when it comes to breaks. plus not too many pple will be able to tell the difference between the stock ef front brakes over something bigger but still from honda so its not really bling
sorry guys im a complete noob to ef's i found a really clean one(not as in jdm or w/e but as in no rust and decent condition chassis on has 99k) so im trying to get some info on this thing.
Im guessing with those front knuckles i can run the integra rotor and caliper set up just da or can u run dc too?
^ we figured that out. when he first posted the t in fast was missing.
and 90renosedan the one im lookin at is a 91 dono if its ex or not
EDIT: EX sedan
i'm not trying to cause a h-t argument. its also a preference thing for me, when you can go into the autoparts store and ask for civic parts on your civic. instead of acura parts on your civic.
Check out the FAQ stickys they have alot of helpful/useful things https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/<~~~FAQ 2.0
as far as your bigger brakes... here's a cheap good route https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/easiest-brake-upgrade-you-never-knew-about-details-inside-1171175/
Another option, if you have the DX or Si knuckle, is to use the Corrado rotor like already mentioned and S2K or RSX Type S calipers. You will only need to buy hub rings for the rotors since the center bore is slightly bigger and you will have to slightly grind the center of the bracket so it clears the hat of the rotor...
Dang... I still have a set of SiR knuckles I want to sell. $300 fair with cut brake lines?
SiR is the other option not listed in the thread.
Same suspension geometry as the stock components.
Uses EX/DA brake components.
Is more durable than EX because knuckle is thicker/beefier.
Uses larger DA wheel bearing.
Accepts B series axles without removing dust ring.
Downside - Tie rod hole is located further inward and requires a minor mod to outer tie rod to compensate for toe (cut off some threads).
