93 CIVIC EX runs lousy when warm....
Old Jan 7, 2010 | 05:52 AM
Slamminmofo2k7's Avatar
Default 93 CIVIC EX runs lousy when warm....
this just started recently... The car runs fine when cold for about 10-15 minutes, and then when at normal operating temperature, it starts getting sluggish, stuttering, etc... At lights it sounds lke its missing and you can see the headlights dim a bt while the tach goes down then jumps a bit.
I've read similar issues but not one really told what was causing it. Has anybody experienced this? Car is well maintained, not beat.
New wires and plugs about 1 year ago (still not ruling this out). new cap and roto about 3 years ago... I still want to take a peek at them again. o2 was replaced about 3 years ago also but can still be that I suppose.
No white smoke from exhaust (would prob eliminate head gasket) and lots of exhaust coming out of pipe (would prob eliminate clogged cat)
Any suggestions?
Old Jan 7, 2010 | 06:57 AM
shoklid's Avatar
Default Re: 93 CIVIC EX runs lousy when warm....
does turning lights on or heater make it worse? if so maybe alternator or charging system failure somewhere
Old Jan 7, 2010 | 07:39 AM
No, not that I noticed.... Everything runs fine until the engine is warmed (10-15 minutes after driving). I believe the lights dim because the rpm drop so low when the car starts acting up.
Old Jan 7, 2010 | 09:49 PM
tommyboy4's Avatar
New User
I have the exact same problem. It seems to idle down to a stall.
Old Jan 8, 2010 | 05:14 AM
Mine hasnlt stalled (yet) but it sure comes close at times.... I may change the o2 today to a spare one I have and see what happens.
Does anybody know if its possible to have no CEL on OBDI with a bad O2?
Old Jan 8, 2010 | 06:58 AM
Former User's Avatar
Yes, an O2 sensor can be bad without a CEL. Unplug the O2 sensor to see if the problem goes away. If so, the O2 sensor is likely bad.
Old Jan 13, 2010 | 09:22 AM
ok... a little update.... I changed the o2 back to the original oem Honda o2... the car ran somewhat better but eventually started the same stuff (but it seemed not as bad)....
I started lookeing at different things under the hood... took off thr dist cap and there was a pile of rustyl colored dirt or soot in there. Cleaned it out with a chemical and put it back on. tried to start the car, and it did a backfire type sound. I dont think I let the cleaner dry as long as I should have and I took the cap back off and notices the coil post was loose and it broke right off when I touched it..
Now, is it hard to change that or should I just buy a whole new distributor since mine is original (1993 ex)??
Old Jan 13, 2010 | 09:28 AM
The red dust is a clear sign that the distributor bearing is shot. Replacing the distributor is straightforward -- remove three bolts, unplug connector and plug wires. You should check the ignition timing when done.
Old Jan 13, 2010 | 09:32 AM
Thanks for the input Ron... so, does my original issue describe that the distributor may have been going? Ran ok when cool (slight miss here and there) but when warm, run like crap and bog down a bit? Can somewhat babied and never beat
Old Jan 13, 2010 | 09:37 AM
My recommendation is that you replace the entire distributor. My guess is that this will solve the original problem.
Old Jan 13, 2010 | 09:43 AM
Thanks Ron... Also, what distributor would I need? 1993 EX. Is that a TD-42U? Any reputable places I should be looking at to buy?
Old Jan 15, 2010 | 10:28 AM
OK... replacement distributor came in.. I put it on, reconnected all wires and no start (yet). I only tried twice.. one was a slight backfire. Now, what I am wondering... i have read where the dizzy can only go in one way, correct? I mean, the shaft of the dizzy (or key) cannot go in upside down (180 degrees off), could it? I just want to make sure before I go nuts over this.
Old Jan 16, 2010 | 07:58 AM
UPDATE - Got it running this morning... So far so good. Took it for a long ride and no stall after it reached normal operating temp. So if anybody h ad the same symptoms, def check your distributor.
Shmzr
Nov 17, 2017 02:19 PM
BallroomDancer1
Honda Civic (2016 - Current)
Jan 2, 2017 08:40 PM
onebadfntsi
14
May 26, 2013 09:51 PM
medjosh6
Honda Civic (2001 - 2005)
Jul 21, 2009 05:03 PM
dmxsoulja3
12
Dec 24, 2004 11:55 AM
