fabricating charge pipe and exhaust is chop saw ok?
Old Jan 6, 2010 | 11:41 PM
cantaffordaccord's Avatar
Default fabricating charge pipe and exhaust is chop saw ok?
so I have limited tools do I need to rent or buy a bandsaw to fab up my aluminum charge pipes and 16ga 3" mild steel exhaust?
or will a chop saw be sufficent?
any tips on cutting ect. would be appreciated
thanks!
Old Jan 7, 2010 | 09:26 AM
Default Re: fabricating charge pipe and exhaust is chop saw ok?
damn i'm feeling dumb wrong forum
Old Jan 7, 2010 | 11:14 AM
Turbo-LS's Avatar
chop saw will work but leave very rough edges, just be sure to clean up and bevel the edges for welding. I've found that a sawzal with The Torch blade by millwalkie (sorry for misspelling) works about like the bandsaw will, just have to have a good clamping system to hold the pipe or a strong friend LOL
Old Jan 7, 2010 | 11:20 AM
Tjabo's Avatar
I imagine I'll get flamed for this, but what the hell, it might help. Anyway, I found out the other day that a regular old circular saw for wood does a pretty good job on aluminum (cut off the runners of an intake manifold like a hot knife through butter), and doesn't leave all of that melted, deformed material that the chop saw does--assuming I'm understanding what a "chop saw" is. If you have a nice compound miter circular saw, you could make sweet cuts super easily.
Old Jan 7, 2010 | 11:24 AM
Turbo-LS's Avatar
Correct Tjabo a circular saw with the righ blae will work just fine. Really aluminum is soft and just about any fast move blade will slice through it
Old Jan 7, 2010 | 11:28 AM
Tjabo's Avatar
Thanks for not beating me up! ! ! !
LOL. . .
Old Jan 7, 2010 | 11:30 AM
Turbo-LS's Avatar
no problem, its ghetto but it will work, im all about making due with what you have at hand. i made my own steel charge pipes back in the bay 3" with a chop saw and a dremel to clean up edges and bevel LOL
Old Jan 7, 2010 | 11:31 AM
icucnme's Avatar
I made all my own charge pipes and 3" exhaust out of stainless steel pipe. Just clamped it in the bench vice and used a sawzall with a metal blade. Then took a porting bit on a drill and deburred the inside of the pipe. I didn't experience any trouble with this.
Old Jan 7, 2010 | 11:56 AM
00si2's Avatar
I used a mitre saw with an abrasive blade to cut steel piping and it worked fine. Although i had to remove some of the plastic protective pieces off of the saw because the sparks started melting them.
If you don't have a dremel a metal file works fine for de-burring.
90Rexx
Welding / Fabrication
12
May 22, 2010 03:56 PM
TVT_DESIGN
Jan 2, 2008 02:24 PM
Luchini
Aug 15, 2006 10:00 AM
1SlowSi
Mar 28, 2005 01:55 PM
