Fuel pressure. But car wont start.
Old Jan 6, 2010 | 05:37 PM
4tika4's Avatar
Default Fuel pressure. But car wont start.
My car wouldnt start one day. Well it would, but only for a second. It would fire up, but as soon as I let the key out of the ignition position, it would die.
Then i got it running. So i let it warm up. Then i drove it around the corner, and it just died on me. Then it was doing the same thing, only starting for a second. Then I finally got it to run again and drove it back.
Now it wont start at all. I thought it might be a fuel pump because i cant hear the fuel pump when i turn my car on. But i still have fuel pressure when im trying to start it.
Any ideas?
Old Jan 6, 2010 | 05:44 PM
Supahatch's Avatar
Default Re: Fuel pressure. But car wont start.
first thought would be ignition switch! try wiggle the key a bit and see what happens
4tika4's Avatar
But it would die while i was driving
Old Jan 6, 2010 | 07:21 PM
D16SiHatch's Avatar
still could be ign switch. specially after reading your symptoms. test it and find out
http://mycomputerninja.com/~jon/IgnitionSwitch.html
Old Jan 6, 2010 | 09:01 PM
4tika4's Avatar
So it could die while im driving if it was the ignition switch?
Old Jan 6, 2010 | 09:33 PM
Choy's Avatar
clean out the fuel rail and whatever the little thing on the left side of the fuel rail. almost the same thing was happening to me. just mine as well clean the whole thing.
Old Jan 6, 2010 | 09:36 PM
4tika4's Avatar
I think it is the ignition switch now. After doing some youtube research.
But can My car just shut off if that is the problem?
Old Jan 6, 2010 | 09:38 PM
Choy's Avatar
But can My car just shut off if that is bad?
well its probably not good. XD
Old Jan 6, 2010 | 09:43 PM
4tika4's Avatar
Haha, i didnt mean to say "is that bad"
i have been thinking with my hands not my brain tonight.
IM PISSEd
Old Jan 7, 2010 | 04:29 PM
4tika4's Avatar
YES. I went to the junkyard and picked up an ignition switch from a hatch. And it Starts and i drove it around.
BUT. the heater doesnt work. it wont blow air at all. This only happens when the car is started.
I had the battery disconnected while i was working. any ideas?
realistpnoy
Aug 13, 2013 08:22 PM
gtifanboy
Mar 12, 2013 07:28 AM
wabyeg6
Nov 18, 2010 12:56 PM
EGNA
Jul 12, 2006 03:31 PM
EK k kay
Dec 16, 2004 08:05 PM
