jdm b16a vs b18c1
Old Jan 6, 2010 | 03:06 PM
phelpsj2's Avatar
Default jdm b16a vs b18c1
Im thinking about doing a swap in the near future and i was wondering everyones opinions on which engine is better? my car will be a DD. what are some pros and cons of each. which would you rather have. what modifications should i do. my goal is around 200hp
phelpsj2's Avatar
Default Re: jdm b16a vs b18c1
its a 97 coupe btw
Old Jan 6, 2010 | 03:10 PM
92bseries's Avatar
research and choose
Old Jan 6, 2010 | 03:12 PM
itsnotfast's Avatar
JDM B16A
Power: 160ps (118 kW) @ 7,600rpm & 15.5kgm (152 Nm) @ 7,000rpm
JDM B18C
Power: 200ps (147.10 kW/ 197.26 HP) @ 8000 rpm & 17.5kgm @ 7500rpm (96 spec) 18.5kgm @ 6200 rpm (98 spec)
Old Jan 6, 2010 | 03:13 PM
Rime.'s Avatar
New User
the search button and google is your best friend.
but if you just want the mosy hp (no other factor) i say go with the b18c1, if its in your budget.
Old Jan 6, 2010 | 03:27 PM
yoontim23's Avatar
Gsr would be easyer to reach your hp goal.
Old Jan 6, 2010 | 03:50 PM
Beckerton's Avatar
Originally Posted by itsnotfast
JDM B16A
JDM B18C
JDM B16A is 160HP or 170HP, depending on the generation of engine.
Old Jan 6, 2010 | 03:56 PM
Beckerton's Avatar
*DOUBLE POST*
Old Jan 6, 2010 | 04:12 PM
phelpsj2's Avatar
are they both about the same to swap in. what would i all need for the swap?
Old Jan 6, 2010 | 04:40 PM
ap1 george's Avatar
JDM B16A
JDM B18C
OP said b18c1 usdm it's not 200ps but I'm sure it's still a better choice than a jdm b16a regardless of generation since it has a higher displacement
Old Jan 6, 2010 | 04:50 PM
crvtectim's Avatar
B16 will lack power and torque in comparison to the B18C1. Also the type r transmission has really nice short gears and lsd for great acceleration. I would choose the B18C1. As far as the swap components involved with either motor should be about the same Good luck with your build!
Old Jan 6, 2010 | 04:54 PM
Deetz's Avatar
Crazy Honda Guy
Go B18C.....it makes more torque...Honda engines need all the torque they can get, it's IMPORTANT!!!
Old Jan 6, 2010 | 05:26 PM
hannslebo's Avatar
b16 since your planning around 200hp. promise
Old Jan 6, 2010 | 05:58 PM
DVDr's Avatar
Whats your budget, if all things equal.
the B18c1 will be nicer, it has all the pros from the b16 plus more.
I cant really see that the B16 would be better in DD form than the GSR motor.
Old Jan 6, 2010 | 06:54 PM
phelpsj2's Avatar
well about how much more would the b18 be than the b16. i dont know where to really look for motors. anyone have any suggestions??
Old Jan 6, 2010 | 07:10 PM
D16SiHatch's Avatar
www.hmotorsonline.com
www.tigerjapanese.com
Old Jan 6, 2010 | 07:26 PM
iamthefollower's Avatar
I honestly LOVE my b16a, but it's lack in torque has made me turn to a b18 motor, so i'm doing an LS/Vtec for the Torque, although I have chose to boost my car also.. but honestly the b18c1 would be the better motor if you are just trying to reach 200hp and let it ride as a DD. You can check your local craigslist for a b18c1 engine.. I know I see them a lot on mine for around $1,500 for motor, tranny, axles, and ecu. Just research around for prices and everything.
Old Jan 6, 2010 | 07:45 PM
phelpsj2's Avatar
i been looking online at jdm motor websites. are those legit?
Old Jan 6, 2010 | 07:47 PM
Yes, they are legit. I bought my motor from a JDM Store here close to me and they treated me very well. I haven't dealt with tigerjapanese, but hmotorsonline I have and they are very good people and ship very quickly.
Old Jan 6, 2010 | 07:57 PM
B16aEk4drbeater's Avatar
B18,,, no ands, ifs, or buts !!!! Trust me, I have a Jdm B16a and I will take a B18c1 any day over it
Old Jan 7, 2010 | 11:27 AM
phelpsj2's Avatar
alright thanks alot man. i think ima go with the b18
Old Jan 7, 2010 | 01:43 PM
hannslebo's Avatar
what a fvck up
Old Jan 7, 2010 | 02:30 PM
o_0's Avatar
o_0
gsr longblock for more hp and b16 tranny for shorter gears
Old Jan 7, 2010 | 02:47 PM
93egSLEEPER's Avatar
im doing a gsr w/ jdm b16 pistons, b16 head w/ type r cams and a lsd b16 tranny. why not do a small custom build that will walk all over either? mine should be comprable to a itr swap, possibly a bit better. ill be running right at 11.5:1 compression ratio.
Old Jan 7, 2010 | 04:39 PM
o_0's Avatar
o_0
my friend put jdm b16 pistons on his gsr block with b16 and b16 tranny. those pistons made a big difference
