jdm b16a vs b18c1
jdm b16a vs b18c1
Im thinking about doing a swap in the near future and i was wondering everyones opinions on which engine is better? my car will be a DD. what are some pros and cons of each. which would you rather have. what modifications should i do. my goal is around 200hp
Re: jdm b16a vs b18c1
JDM B16A
Power: 160ps (118 kW) @ 7,600rpm & 15.5kgm (152 Nm) @ 7,000rpm
JDM B18C
Power: 200ps (147.10 kW/ 197.26 HP) @ 8000 rpm & 17.5kgm @ 7500rpm (96 spec) 18.5kgm @ 6200 rpm (98 spec)
JDM B18C
OP said b18c1 usdm it's not 200ps but I'm sure it's still a better choice than a jdm b16a regardless of generation since it has a higher displacement
B16 will lack power and torque in comparison to the B18C1. Also the type r transmission has really nice short gears and lsd for great acceleration. I would choose the B18C1. As far as the swap components involved with either motor should be about the same Good luck with your build!
I honestly LOVE my b16a, but it's lack in torque has made me turn to a b18 motor, so i'm doing an LS/Vtec for the Torque, although I have chose to boost my car also.. but honestly the b18c1 would be the better motor if you are just trying to reach 200hp and let it ride as a DD. You can check your local craigslist for a b18c1 engine.. I know I see them a lot on mine for around $1,500 for motor, tranny, axles, and ecu. Just research around for prices and everything.
Yes, they are legit. I bought my motor from a JDM Store here close to me and they treated me very well. I haven't dealt with tigerjapanese, but hmotorsonline I have and they are very good people and ship very quickly.
im doing a gsr w/ jdm b16 pistons, b16 head w/ type r cams and a lsd b16 tranny. why not do a small custom build that will walk all over either? mine should be comprable to a itr swap, possibly a bit better. ill be running right at 11.5:1 compression ratio.
