B16a into ej1
ok so ive decided to take the b16 from my ef and drop it into the ej coupe.can anyone tell me everything i need to complete the swap?.i know i need mounts.. i have si axles.and a vtec ecu.what else? thanx.
we all do a million times u have axels & ecu. hmmm how about integra shift linkage and rear mount even stock eg eh ej moto mounts will work as well. if you got the engine harness to your 92-95 retro that on the b16, and get electric tranny speedo,if your cars not ex or vx vtec&knock are 3 wires away. if u juz geta hydro bseries tranz it be so ez this motor would bolt itself in there.
thanks this helps alot... thing is i like my tranny i just rebuilt it.the ej is an ex..
so you are saying that the stock motor mounts will fit? and i cant use the shift linkage from the single cam?
yah youll need custom hasport to hydro 2 cable.and yah the mounts werk but youll need a hasport cable m mount now since u want to use a cable tranny in ej. if you had hydro tranz the stock eg mount will werk, cable trans gota dfrnt hole pattern. and no ur rex linkage is to short 4 that car.
and in my 1st post wen i said rear mount i meant 94-01 rear engine bracket, leave da stock rear engine m mount alone.it will allbolt to it. and if you probly had da style post mount from ur rex use it onda ej.
b16 or gsr well vtec trannyz are radikol , but if u plan on boost the dey say ls tranny cuz itz ez long gears,i use vtec tranz with boost so if your good at da pedal u can spank on em! but im a consistent as hell wen it kumz down to the light. itz on u man ls trannyz r ezr to get than short gear vtec 1s and cheaper.
Heavy Pee
Jan 11, 2005 05:04 PM
gsrhb7
Aug 9, 2004 12:52 PM
