Auto Tranny Question
just got done with my d16z6 swap in my dx i kept it auto but i ised the DX tranny now anytime i drive it it will still shift at the 6500 it did shift at with the d15b7 it should be shifting at the 7200 or so right? i have a chipped p28 if you guys need any other info just let me know
What ECU did you use? The P06 for the D15B7 would be programmed different and since it controls the ECU and motor, you need to run a P28.
Honestly, I don't see the point of swapping a better motor in unless you convert to manual. It will be a bit better, but a automatic is aweful for performance, and every little bit of power you can get is worth having on these little motors.
