New slave and clutch cylinder not working
Old Jan 6, 2010 | 09:54 AM
thegatekeeper14's Avatar
Default New slave and clutch cylinder not working
I just installed my new clutch cylinder and slave cylinder, my friend and I bleed the system untill there was pressure in the peddel so we continued. But nothing changed, fluid is fine. Does that rod that connects to the peddel need to be adjusted? Because there is only pressure aginst the peddel about an inch from the floor.
This is my DD so any help would be great.
Old Jan 6, 2010 | 01:43 PM
delsolproblems's Avatar
Default Re: New slave and clutch cylinder not working
The pedal adjustment is not your problem. You say it has pressure an inch from the floor. Does that pressure ever lessen or go away after pressing the pedal alot? Make sure you are bleeding it properly. Air can get in through the bleeder screw if it is open when fluid is not being pushed out.
Old Jan 7, 2010 | 09:48 AM
I belive I need to adjust the rod a tad and seen I'm leaking from the resivor nipple.
Dool_Ohver_Hed_Cam
Jul 3, 2007 06:01 PM
Mr.Luder
May 24, 2006 08:41 PM
matto2413
Jul 16, 2005 07:08 PM
92LudeSI
Jul 13, 2005 08:23 AM
98 blacksh
Jan 10, 2005 03:45 AM
