Car shakes when braking dont Kno why !!
93 civic lx
recently swapped motor
the hole car shakes when braking after going 40 or more mph
warped rotor ?
is it the alignment ? do i need one
rack and pinion ?
AND cars pull to the right very crazy when i gas it
Need help pls thanks
warped rotor ?
rack and pinion ?
first check suspension bushings for wear. check tie rods and ball joint for play. machine or change rotors and pads. could be warped or have pad deposits. check tire pressures and alignment.
CBL9
Nov 11, 2010 10:28 AM
