vitara y8 running on 2 cylinders
Old Jan 5, 2010 | 01:27 PM
dohc4life's Avatar
Icon6 vitara y8 running on 2 cylinders
complete d16y8 swap with z6 manifold and obd0 dizzy vitara pistons, pretty much everything else is stock, dx to mpfi wiring harness but no resistor box i just twisted the wires together as known,
car gets fuel on all cylinders and spark, but its not running on cylinder 1&3 i think it could be the timing but ive tried it a million different times and it still wont run right, i need some help thanks
Old Jan 5, 2010 | 01:31 PM
turbohatchBnuts's Avatar
Default Re: vitara y8 running on 2 cylinders
double check and make sure your injectors are working properly
Old Jan 5, 2010 | 01:34 PM
dohc4life's Avatar
thats what my next thing was gonna be, i had almost the same problem with my old motor d15b2 block z6 head and it was the timing and fuel also i used a different engine harness this time so ill see thanks anything else??
Old Jan 5, 2010 | 05:35 PM
EK_RedSiR's Avatar
double check your timing and are you throwing any codes?
Old Jan 5, 2010 | 06:17 PM
dohc4life's Avatar
its only throwing a code 1, but ive gone over the timing over and over and it still wont run right it has fuel and spark on all 4 cylinders i dont know what it could be ive re adjusted the valves also they are perfect
Old Jan 6, 2010 | 08:10 AM
make sure u got the right order for your spark plug wires
what dizzy are u using?
Old Jan 6, 2010 | 09:00 AM
bori21's Avatar
New User
do a compression check. and what computer r u runnin??
Old Jan 6, 2010 | 09:15 AM
4drEF's Avatar
Keyboard Humorist
Old Jan 6, 2010 | 02:30 PM
dohc4life's Avatar
its a chipped obd1 p28 and i have a conversion harness, i used to have a d15b2 block and z6 head same injectors same manifold on my new motor, im not sure what dizzy it is, but it was on the motor when i got it and it ran like that, im not sure if its an obd0 dizzy because it bolts right up i think they may have changed the plugs to obd0 but i really have no idea what the f it could be, it runs on 2 cylinders like a champ and dumps fuel out number one exhaust port
Old Jan 6, 2010 | 03:22 PM
4drEF's Avatar
Keyboard Humorist
.. so how did that compression check go?
Old Jan 6, 2010 | 03:28 PM
dohc4life's Avatar
havent tried that yet but i will when i get home, thanks for the advice anything else would also help im punching myself in the face for this one lol
Old Jan 6, 2010 | 04:14 PM
leteg98's Avatar
make sure that the dizzy is for the right obd and do you have some kind of tune on the car?
Old Jan 11, 2010 | 01:35 PM
dohc4life's Avatar
its the same ecu thats been ran on like 4 different motors, just launch control and 9k rev limiter and 54k vtec, but its the dizzy that came with the car and the guy said it ran fine i think its an obd0 ls ecu and we changed the plugs to obd1 plugs to match the ecu and harness
waynesumner
36
Dec 6, 2013 05:57 PM
bunnyx
Jun 10, 2013 07:04 AM
spens 91 Ef
Jan 22, 2011 09:20 AM
dohc4life
14
Jan 11, 2010 05:06 PM
QuarterMileMaster
Aug 29, 2009 08:39 PM
