Why would someone cut distributor wires?
Old Sep 3, 2002 | 09:07 PM
ScottEK's Avatar
Default Why would someone cut distributor wires?
I'm looking into buying a used ZC engine, then only two things the guy could name that were wrong with it is
"The distributor wires were cut, but retaped and also the timing belt cover was chopped by this guy too. "
Are these that bad of a problem, what wires could be cut going to it, is it a harness or something. Thanks
Old Sep 4, 2002 | 06:14 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Why would someone cut distributor wires? (beta13)
Cause they were in a rush or didn't give a ****.
Old Sep 4, 2002 | 07:16 AM
JD_B18CDX's Avatar
Assuming it was not a rush job......or sloppy shipment
Cut Valve cover = Cam gears... engine probably had some sort of cam gear and cutting the valve cover would facilitate access for tuning.
Cut distributor wires = Previous owner was running a different ECU from the original... like OBD0-OBDI or OBDII. OR just running a different ignition trigger mechanism.
Squeek485
Jan 26, 2017 10:54 AM
MinimusMaximus
Apr 24, 2015 02:58 AM
cars
Aug 10, 2010 08:53 AM
Casey
Jul 28, 2003 02:15 PM
