Wanted to replace 32mm wheel bearing, CTR 5 lug conversion
I need to replace my 32mm wheel bearing on my CTR 5 lug conversion I did on my 95 civic hatchback. Can anyone tell me where I could purchase new wheel bearings? What other honda vehicles uses the same wheel bearings?
ive heard that the 2wd crv uses the same same knuckles and spindles and such as the 5 lug itr's. im not sure if its the same for the ctr though. if they are the same, i figure you could just order parts for a crv.
Thanks for the info... I'll call the dealers here. Is all the bearings the same size? The one's I need to replace is the rear. It make alot of noise like nobbie wheels running on the highway.
I know about the axles, but Im are asking if the wheel bearings are the same off a jdm itr vs the usdm itr since its a 32mm and the jdm itr are 36mm.-(front)
i don;t believe they will fit in the same hub, never tried it personally but i'm pretty sure the 36mm is a much larger diameter than the 32.
if memory serves me right the JDM 36mm axle is indeed larger than the USDM 32. Wait, isn't that obvious?
You could see if an Accord or Prelude or CRV use the same part number...
RevIllusions
20
Feb 18, 2015 05:40 PM
