Wanted to replace 32mm wheel bearing, CTR 5 lug conversion
Old 01-04-2010, 06:07 PM
New User
Sams K's Avatar
Default Wanted to replace 32mm wheel bearing, CTR 5 lug conversion
I need to replace my 32mm wheel bearing on my CTR 5 lug conversion I did on my 95 civic hatchback. Can anyone tell me where I could purchase new wheel bearings? What other honda vehicles uses the same wheel bearings?
Old 01-04-2010, 06:56 PM
hondadude_rudo's Avatar
Default Re: Wanted to replace 32mm wheel bearing, CTR 5 lug conversion
ive heard that the 2wd crv uses the same same knuckles and spindles and such as the 5 lug itr's. im not sure if its the same for the ctr though. if they are the same, i figure you could just order parts for a crv.
Old 01-04-2010, 06:59 PM
forcefedferio's Avatar
Just get them for the USDM 97-01 Integra Type R. The only ones that would be different is the JDM ones that are 36mm
Old 01-04-2010, 07:15 PM
hYbRid_Eg6's Avatar
so how about the 36mm ones, which car can get them from?
Old 01-04-2010, 07:18 PM
JDM integra type R's, but you have to make frankenstein axles for them to work for you, unless you get factory 36mm axles too.
Old 01-04-2010, 07:43 PM
New User
Sams K's Avatar
Thanks for the info... I'll call the dealers here. Is all the bearings the same size? The one's I need to replace is the rear. It make alot of noise like nobbie wheels running on the highway.
Old 01-04-2010, 09:01 PM
hYbRid_Eg6's Avatar
I know about the axles, but Im are asking if the wheel bearings are the same off a jdm itr vs the usdm itr since its a 32mm and the jdm itr are 36mm.-(front)
Old 01-05-2010, 07:43 PM
i don;t believe they will fit in the same hub, never tried it personally but i'm pretty sure the 36mm is a much larger diameter than the 32.
Old 01-05-2010, 08:20 PM
thumper64's Avatar
if memory serves me right the JDM 36mm axle is indeed larger than the USDM 32. Wait, isn't that obvious?
You could see if an Accord or Prelude or CRV use the same part number...
Old 01-05-2010, 09:01 PM
atleast someone else is working off the same theory
Old 01-05-2010, 09:52 PM
thumper64's Avatar
I don't know if saying the 36mm is "much larger" than the 32, I'd say it's marginally bigger...like 4mm. haha.
RevIllusions
20
02-18-2015 05:40 PM
eg94coupejdm
04-20-2011 03:15 PM
TerribleToo
03-05-2010 01:08 PM
AK94GSR
09-27-2006 04:40 PM
Quick Reply: Wanted to replace 32mm wheel bearing, CTR 5 lug conversion
