Surging and jerking while accelerating!
Old Jan 4, 2010 | 04:25 PM
lexluther's Avatar
Default Surging and jerking while accelerating!
Did HG job, compression is even across the board, 180 PSI, timing is on, dizzy is 16 degrees BTDC, i had to replace the crank sensor yesterday, because the alt belt cut into the harness and shorted a couple wires... giving me a P1337 code.. anyway that is fixed, but when i accelerate, it isnt smooth, it kinda jerks, and surges... no codes.... no fun at all, this car just seems to be falling apart..!!! its a D16Y7.
Any ideas?
Old Jan 4, 2010 | 05:10 PM
vlc92189's Avatar
Default Re: Surging and jerking while accelerating!
i know this sounds really weird, but this is what happens to me. the screw where you can turn your idle up and down is what makes my car jerk and surge. if its too open meaning the screw is turned to the left too muchh then my car surges and sometimes jerks. turn the screw to the right some, hope this helps.
Old Jan 4, 2010 | 05:32 PM
lexluther's Avatar
hey thanks for the reply! I dont think i know the screw your talking about, i thought the only screw that would effect idle was on the throttle body... and all it does is kinda opens the throttle a little to make the idle go up some. whatever the problem is, it isnt tripping a code, its not compression or timing... could that crank sensor have damaged the Ignition module..?
Old Jan 4, 2010 | 06:51 PM
lexluther's Avatar
Hello?
Old Jan 7, 2010 | 06:47 AM
vlc92189's Avatar
yes its on the throttle body, and i know it sounds weird. thats just the problem with mine, when it is too open the car surges, and sometimes since my screw becomes loose, the car surges and jerks when it is at a certain point. this may not be your problem, im just letting you kno
Old Jan 7, 2010 | 06:53 AM
shoklid's Avatar
take spark plug wires off and check for oil. maybe bad valve cover rings. will make car run like poop if no correct spark
Old Jan 7, 2010 | 07:04 AM
lexluther's Avatar
No oil, completely dry....thanks for the input tho.... whatever it is, is affecting my gas mileage, i went from 40 to 31!!!.... i am leaning toward the spark module, only because the crank sensor was basically shorted out when the alt belt cut into it, that could have caused damage upstream.. its not a miss, it does have a minor engine jerk at idle, very minor... and a surge or jerk when accelerating... the only engine code i am getting, is cat efficiencey low, due to not cat!!... i have gotten this code since day one.... its not the problem, ran perfectly well that way for a year now.
Old Nov 13, 2011 | 02:02 PM
warlock3055's Avatar
hello, i have the same problem. did you figure it out what was causing this issue? please let me know. thanks
Dylanthoms
Apr 24, 2018 08:52 PM
Problemo
Jan 29, 2006 04:16 PM
madcrossover
Jul 2, 2005 10:18 AM
kaj
Sep 1, 2004 04:37 PM
TheHatchHog
May 15, 2003 06:16 AM
