4-wire 02 pinouts?
Old Sep 3, 2002 | 09:00 PM
MackSpeed-616's Avatar
Default 4-wire 02 pinouts?
I have a sensor that lost its plug so i have to repin it. I assume the white is the signal positive and the other colored wire (green?) is the positive heater wire. Then the other 2 are signal ground and heater ground, right? Can i ground these to either of the remaining 2 locations or does it matter which ground it gets. I assume a ground is a ground.
Old Sep 3, 2002 | 09:11 PM
Reid's Avatar
Global Moderator
Default Re: 4-wire 02 pinouts? (BustaNutt-616)
The grounds actually do matter, IIRC.
But if you're wrong you just need to switch them.
Old Sep 3, 2002 | 09:17 PM
Default Re: 4-wire 02 pinouts? (Reid)
ok thanks. id rather "measure twice, and cut once" though. how can i figure out which ground is which?
Old Sep 4, 2002 | 02:37 AM
kenji's Avatar
25 Year Member
yel/blk - 12v switched - black wire on O2 sensor
org/blk - heater control - black wire on O2 sensor
wht/red - O2 signal - white wire on O2 sensor
grn/wht - sensor ground - green wire on O2 sensor
-kenji
Old Sep 4, 2002 | 04:42 AM
Default Re: 4-wire 02 pinouts? (kenji)
-kenji
ok kenji, that helps. but now, what do i do to determine which black wire on the sensor goes to the 12v switched and which goes to the heater control?
Old Sep 4, 2002 | 06:41 AM
kenji's Avatar
25 Year Member
You can either flip a coin or look at a buddy's O2 sensor. Switching the wires is no big deal. If you throw a code you switch them back. No worries...
-kenji
Old Sep 4, 2002 | 07:06 AM
Warren's Avatar
Wrong-Way Wang
Hmm, I guess I lucked out then. I forgot to check the grounds before I cut and extended my current O2 sensor for my SMS header. No codes.
Warren
Old Sep 4, 2002 | 07:15 AM
flip a coin.. good idea, except it would be hard to determine which wire would be heads or tails, b/c they look the same
Old Sep 4, 2002 | 09:56 AM
sgT's Avatar
sgT
blacks dont matter.
Old Sep 4, 2002 | 09:58 AM
Reid's Avatar
Global Moderator
Default Re: 4-wire 02 pinouts? (sgT)
blacks dont matter.
Really?
That makes life easier.
[Modified by Reid, 8:58 AM 9/4/2002]
Old Sep 4, 2002 | 10:10 AM
blacks dont matter.
my father told me we were just as important as any other race
Old Sep 4, 2002 | 10:11 AM
Reid's Avatar
Global Moderator
LOL
dc4drewH
Aug 17, 2006 09:02 AM
RobbieG35
Jun 21, 2006 07:29 AM
WhiteVX
Sep 29, 2004 02:12 PM
HXMan
Apr 26, 2002 08:13 AM
Tony the Tiger
Oct 23, 2001 10:55 PM
