EG B18C Wiring with ECU Jumper Harness
Perhaps an elementary question, but here goes:
Motor to be swapped: OBD2 JDM B18C (year 1998)
Vehicle to receive swap: 1994 EG Hatch SI
I'm going to use the JDM OBD2 ECU.
My question is regarding the wiring for the knock sensor and IABs: when using a jumper harness to use an OBD2 ECU in an OBD1 car, will I run the wires to the original ECU plugs in the cabin or to the end of the jumper harness that's actually plugged into the ECU?
Thanks in advance.
Sean
Thanks in advance.
Sean
JimmiMorris
Jan 24, 2012 04:25 PM
jdmchickx
10
Oct 26, 2011 06:03 PM
hybrid_eg
Oct 20, 2003 11:32 AM
