the EF nightmare continues
Old Jan 3, 2010 | 10:56 PM
weggies4life's Avatar
Default the EF nightmare continues
i bought a 89' hatch and i have no clue what wiring harness i have so if anyone can tell how to distinguish it i'd really appreciate it.
also i just put in a d15b7 in and i am running a virgin pr4 ecu so i have the following problems:
1) no spark but i have no idea what dizzy i am using
2) i only get one click from the main relay
3) i have a cel that i can't jump if my life dpended on it, and i have tryed with 2 diff. ecu's
4) the fuel pump is getting just about 5 volts, i tested it by putting a volt metter to it and it only gets power when i turn the motor over, otherwise i don't get anything
5) i check continuity and only one wire has power all the time when the key is on and while i try to start the car
all the help is greatly appreciated,
Nick
Old Jan 3, 2010 | 11:33 PM
trane1's Avatar
Default Re: the EF nightmare continues
to check the dizzy u r using..check the ingraving on the housing...
google the code and it will tell u what u got..
did u use the wiring from the engine or u re-wired it...
check your grounds...specially the on thatgoes to thethermostat....
check starter..isur battery good...theres alot of possable things....
Old Jan 4, 2010 | 12:12 AM
well on the bottom of where you bolt it up at inbetween the webbing is d-2426 and that is the only number on the whole thing besides what looks like a home-maid inventory number b/c it looks like it was put the by a dye grinder, and i am using the wiring harness that came with the car and i think he was running a d17? all that came with it is the block, i will check the grounds and tell you if that helped any, and yes the starter is good and hooked up right and i have a good battery
Old Jan 4, 2010 | 01:16 AM
well i have the only 2 that i can find inside under the dash grounded, the ones that go to the underhood fuse box and i have 2 grounded to the starter b/c there is no slack to pull the one to the thermostat but i did have the 2 on the thermostat and i have the same thing, i also have 2 what look like relays grounded to the bay but i don't know what they are for. if there are some that i am missing i don't have b/c i checked a few times
Old Jan 5, 2010 | 09:25 AM
isn't there anyone that even wants to throw an idea out here to help me out
Old Jan 5, 2010 | 09:31 AM
turbohatchBnuts's Avatar
i can fix ur car how far are u from jax?
is ur car converted to mpfi?
if not i got alll the stuff u need to do it
yea ur using the wrong ecu u need a pm6 ecu i got stacks haha
need sum pics so i can see what ur working with
Old Jan 5, 2010 | 09:33 AM
Deetz's Avatar
Crazy Honda Guy
Start by using a better ecu!
You are using a PR4, b series LS ecu for a 1.5L d series engine????
Old Jan 5, 2010 | 01:16 PM
akshn1's Avatar
use a pm5 or pm9
Old Jan 5, 2010 | 01:24 PM
Originally Posted by akshn1
use a pm5 or pm9
a pm5 is a dpfi ecu dont use that
pm9 is for dohc zc
Old Jan 5, 2010 | 06:35 PM
well i've actually read a lot of people running it with the pr4 but here is a site with all the pics on it from the dizzy to the engine bay, and i apprectiate your offer turbo but i'd rather doit it myself i just need some tips on what's wrong
http://www.d-series.org/forums/gener...nightmare.html
Old Jan 6, 2010 | 12:52 AM
kwell's Avatar
they run on a pr4 just fine, just make sure you dont hit boost unless thats chipped
Old Jan 9, 2010 | 10:10 PM
well i'm going to the junkyard tomorow, what harness and ecu should i buy to get me reliably running
remember i have a d15b7 with a mpfi mani. and a 89' dx hatch
Old Jan 9, 2010 | 10:57 PM
JDMefHATCH7's Avatar
make sure the wiring on the car was done properly and that you got a resistor box and check if all plugs are getting spark...and go over the engine harness and look for any corroded and fxcked up cables/sensors/plugs
check wassup with your dizzy and plugs and plugs and wire and try running it with a pm6 ecu
However what I would do and is best in your case
try and bring home a whole stock goodlooking engine harness from a civic/crx DX must be DX(make sure to remove it properly and remember where everything goes)
and if you get a chance bring yourself another engine harness(si/hf prefferably in whatever condition(to get missing plugs/wires for a DX mpfi conversion) and a pm6 ecu
and that way get/make yourself a more complete and reliable engine harness(mpfi)
and not have to deal with a shitty beatup harness
1QwIkEf
Mar 24, 2022 09:44 AM
hathbackef1989
Sep 8, 2013 10:14 AM
jdmacuraITR
Feb 4, 2013 05:37 PM
Ayeso
Sep 17, 2006 09:48 AM
