F22B2/F22B1 swap problems
Old Jan 3, 2010 | 06:52 PM
SidewayzCivic's Avatar
Icon3 F22B2/F22B1 swap problems
I just recently blew my 95 F22B2 OBD1 motor and bought a 97 F22B1 OBD2 engine and through it in, I used my OBD 1 ECM,Distributor and wiring harness, the only sensor thats not hooked up is the knock sensor but since my old setup didnt have it and im using that ECM so i figured it wasnt needed. I have fuel,Spark and it turns just cant get it to run...Am I missing something, according to the timing gear and checkin the #1 piston it seems to have perfect timing. Where is the # 1 plug on the distributor?? doesnt it point to the front of the car?? please help me, this not having a car is killing me
Old Jan 4, 2010 | 01:45 AM
GhostAccord's Avatar
Default Re: F22B2/F22B1 swap problems
The #1 plug on the distributor should point up.
Make sure you have your engine harness/ECU grounds connected as well.
Racerwhit
May 17, 2018 07:01 AM
viciousvisionslarry
May 25, 2012 09:45 AM
Speedfiend97LX
Jun 3, 2011 10:20 PM
Honda_Tengoku
Sep 12, 2004 02:08 PM
