how to install tachometer 99 civic dx
Old Jan 3, 2010 | 06:39 PM
hellraiser7492's Avatar
Default how to install tachometer 99 civic dx
Please help out having issues... i r teh nub
Old Jan 3, 2010 | 06:50 PM
Default Re: how to install tachometer 99 civic dx
bump
Old Jan 3, 2010 | 06:58 PM
VihnSta2's Avatar
Not to get all ClubCivic on you, But woulden't it make much more sense in buying a EX cluster with a tach built in?..But if you must here's all i know about that.
Red/White-Cig lighter
Black-Ground
Green-Get a pocket knife and start shaving the wires near your motor until you find it maybe someone on HT can fill that spot for you
Old Jan 3, 2010 | 07:01 PM
Black-Ground
explain green that confuzzled me.
assuming youre not sure.
sorry=drunk
Old Jan 3, 2010 | 07:05 PM
BigCountry's Avatar
Green is what actually is getting the RPM signal.I would honestly just splice into the factory wiring behind the cluster for the green wire. You'll have to look it up. I'm too lazy.
Old Jan 3, 2010 | 07:06 PM
VihnSta2's Avatar
sorry=drunk
Well, i popped my hood and checked for ya
Green- Splice into the wire harness mounted on your distributor there should be a series of wires, Green goes into blue i think it may be blue with a white stripe i'm not sure but it dosen't matter since there is only one blue wire in that.
Old Jan 3, 2010 | 07:19 PM
thecruzs2007@yahoo.com's Avatar
^^ yes it is the blue wire..its by the master cylinder..good luck
Soliveros15
28
Mar 2, 2014 12:46 PM
Danethomp
Sep 18, 2006 11:56 PM
civicEXtreme
16
Dec 11, 2005 02:27 PM
foomashoo
Nov 23, 2004 08:56 AM
gondzur
Aug 30, 2004 08:24 PM
