Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
04 Odyssey Washer Pump Problem Pls Help!!
Old Jan 3, 2010 | 01:34 PM
wiziwig76's Avatar
New User
Default 04 Odyssey Washer Pump Problem Pls Help!!
No fluid comes out when I try to wash the front or back window, and I cannot hear the pump run. Very cold here, but even after running the car for a long while to warm things up, no fluid. The dipstick is stuck in the reservoir (the cap disconnected from the dipstick) - could it be frozen in the bottom? I can't even pull it out with pliers! The wipers turn on and run fine, so I dont think its a fuse issue.
Do I need to replace the pump or could everything just be frozen up? Any ideas would be much appreciated. Thanks all.
Old Jan 4, 2010 | 05:57 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 04 Odyssey Washer Pump Problem Pls Help!!
Everything is frozen. Get some good antifreeze washer fluid and top it off. Best bet is to find a warm garage you can park the van in overnight to let it thaw out.
wdissident
Feb 9, 2009 10:53 PM
Hater01
11
Mar 2, 2008 08:30 PM
burninator
Mar 31, 2005 04:38 AM
mc
Jan 17, 2004 11:37 AM
zijiejijeijrkjk
Mar 15, 2002 05:28 AM
