Engine oil ?
Old Jan 3, 2010 | 04:30 AM
ral24_hct's Avatar
Default Engine oil ?
Hello pls need help to pick a good engine oil for my B20vtec turbo car the option Y have are : Lucas oil 20-50 , Castrol 5-50, Eneos oil 0-50 or 15-40 , Redline 15-50, Shell Ultra 5-40 , Mobil 1 15-50
Witch of this oil will be the best for my car where I live there is no winter and is really hot place. My car is doing 500whp and rev to 9000 rpm
Old Jan 3, 2010 | 05:17 AM
600hpdream's Avatar
Default Re: Engine oil ?
Mobile 1 15-50.
Old Jan 3, 2010 | 07:24 AM
jdm inc's Avatar
brad penn 20w50 http://t1raceparts.com/en/products/d...acing-oil.html
Old Jan 3, 2010 | 08:30 AM
reaction360's Avatar
Originally Posted by jdm inc
this is what's in my car at the moment. Good stuff.
Old Jan 3, 2010 | 11:00 AM
Hondoctors's Avatar
I really like the Eneos 0w-50. That's what I use in my 600 whp Integra, revving to 9200 RPM.
Old Jan 4, 2010 | 01:05 PM
civic_r87111's Avatar
Depending on the use of the engine but for a street car I would use a 10w-30 after that is just a matter of brand pref. I like mobil1 and Royal purpple in my modded engines but if it's just the DD then I use mobil5000. The only time I would use above a 10w-30 is for a race only engine but even then I would only use a 15w-40.
Old Jan 4, 2010 | 02:06 PM
welfarepc's Avatar
lets hear some reasoning for your absurd recommendations.
Old Jan 4, 2010 | 08:05 PM
Well think about the purpose of the oil.. To lube and cool! What is hondas recommended viscosity (10w-30 in most engines, never above), y is that the recommended viscosity?? Because of the clearances of the oil passages! There is no real gain behind using a thick a$$ oil besides a high oil pressure. It doesn't lubricate or cool any better nor does it stop oil consumption. Just because ur oil pressure is higher doesn't mean it's working better either, it just means it's harder for the oil pump to pump it. I'm more interested to hear y u guys think it's better to run such high viscosity oil..! Remember ur not driving old fords or chevy's with sloppy lose tolerances.
Old Jan 5, 2010 | 11:27 AM
Turbo-LS's Avatar
Brad penn racing oil 10w30 offered by t1 racing. 20w50 for a looser motor 10w30 for a stock clearence motor. Thats my 2 penny's
Old Jan 5, 2010 | 11:51 AM
^^ pretty much, the only time I would use a 20w-50 would be if I set my bearing clearances to .0025".
Old Jan 5, 2010 | 11:56 AM
E85B18's Avatar
I ran castrol 20w-50 in my DD. 20,000 miles at 430whp. No problem
Old Jan 5, 2010 | 12:07 PM
I'm not sayin it will absolutly cause problems but it doesn't benifit anything either.
Old Jan 5, 2010 | 01:08 PM
E85B18's Avatar
I hear ya. Im trying to figure out what I want to run in my next build. Im not sure if I want to keep it that thick
Old Jan 5, 2010 | 05:35 PM
jdm602's Avatar
brad penn 10-40 race.
gizzmo222
Aug 14, 2018 07:08 AM
EG-SIXV-TEC
Jun 12, 2010 10:47 PM
Tiwe
May 11, 2003 11:47 PM
_Endless_
Feb 27, 2003 07:37 AM
Fuster_Cluck
Oct 20, 2002 01:34 PM
