Transmission & Drivetrain Gearboxes, Differentials, Clutches
grinds when shifting.
Old Jan 2, 2010 | 06:16 PM
sloaccord97's Avatar
Icon6 grinds when shifting.
i had a 5 speed swap done in my 97 accord. but when i shift gears from 1st to 2nd it grinds sometimes,but mainly 2nd to 3rd. it gets real bad if your giving it hell. what can it be? just so u know my clutch is fully engaged immediately off the floor. i tried to adjust the pedal but not much difference, so could it be the slave cylinder? thanks for any input.
Old Jan 6, 2010 | 05:38 AM
tra1an's Avatar
New User
Default Re: grinds when shifting.
Maybe it's a bad gear box... i knew that the gearbox sounds like that when the synchronizer mechanism (hope i'we got it right, i don't know the exact word in EN) is starting to fail.
Old Jan 6, 2010 | 05:38 PM
94EG8's Avatar
Seagull Management
I've heard you have to reinforce the firewall on '94 - '97 Accords when doing a 5 speed swap because the firewall will flex when you depress the clutch. I'd check that out first, clutch may not be fully disengaged.
Old Jan 8, 2010 | 06:41 PM
i hope its not the trans, ill check the pedal to see if it flexes. i had a guy do the swap for me and i asked him about that and he said it was fine, but i will still check thank you.
S_moore26
Apr 19, 2013 04:33 PM
JKingCivicSi
Dec 19, 2011 05:03 AM
lxdriver
Feb 26, 2011 07:28 PM
2wheelhunter
Jul 13, 2006 09:17 AM
gabhatch
May 24, 2005 09:32 PM
