need help
Old Jan 2, 2010 | 05:51 PM
hatchy sleeper's Avatar
Default help on this code 14 how do i fix it
okay im throwing code 14 in my hatch have a y7 bottom end y7 head and intake mani. i think its my iacv because my rpms bounch at 1800-2100 its not a vac leak i checked and fixed all of them i tryed a new iacv but still does the same and throws the code what should it be now? whats the next step?
Old Jan 2, 2010 | 06:20 PM
Default Re: need help
bump for help
Old Jan 2, 2010 | 07:36 PM
KINGVEM^^ED6's Avatar
Need to make ur post title more clear or people won't bother.......
Old Jan 3, 2010 | 11:17 AM
Thanks for the tip
Bump
QUOTE=KINGVEM^^ED6;41116909]Need to make ur post title more clear or people won't bother.......[/QUOTE]
Old Jan 3, 2010 | 11:41 AM
Fuzzy Rhubarb's Avatar
is it obd0 or 1?
Old Jan 3, 2010 | 12:46 PM
Its obd0 complete y7 with a a6 intake mani. And ls injectors
Originally Posted by Fuzzy Rhubarb
is it obd0 or 1?
Old Jan 3, 2010 | 01:22 PM
OK With ignition on, one side of the plug should be 12v, and the other one goes to the ECU. If you don't have 12v on blk/yel, that's probably your problem. It's fuse #14 under the dash. If you do have 12v, check for continuity between the other wire and A11 at the ECU. They're both blu/yel.
gl
Old Jan 4, 2010 | 06:00 AM
Alright ko ill check it and ill let you know asap thanks
gl
silencedogood
Jan 3, 2012 04:11 AM
backyard_concepts
10
Jan 1, 2010 09:16 PM
slowcrxwannarace
14
May 15, 2006 06:42 PM
aown61
Sep 26, 2005 09:56 AM
