ECT Code. PLEASSSSE HELP!
So i put in a new Y8 and im getting a code 6, I have changed every temp sensor that there is, and im still throwing the code. I have tried reseting the ecu. and it keeps popping up. Any one ever have this problem? Or know how to fix it?? PLEASEEEEEE HELP!
Re: ECT Code. PLEASSSSE HELP!
Well I would start off by checking the basic's. Check wiring/ground. Check that your coolant is flowing properly. Check the temp yourself and refer to the book to see if it's a issue.
well ect code is 86 for the sensor in the head itself. did u change the one closest to your headlights with the green plastic on it
Technical Hero
can you post of picture of your wiring in that area, I know it sounds funny but a guy in here recently did a similar swap, had that code and had switched the wiring for the ECT and the VTEC pressure switch
Thats kinda funny, possible but funny. I'd think he would be getting a code for the pressure switch as well. Maybe not if the ECT sensor eventually sent similar voltage at a certain temp as the VTEC pressure switch signal.
