mpfi tps same as dpfi??
Old Jan 2, 2010 | 10:36 AM
91tegrals's Avatar
Default mpfi tps same as dpfi??
pk so my tps is out and no one has a dpfi car it seems so can i use a reg tps on my car im not sure so thought i would ask before buying one
Old Jan 2, 2010 | 11:27 AM
efhondaracer27's Avatar
Default Re: mpfi tps same as dpfi??
yea you should be able to..
Old Jan 2, 2010 | 02:53 PM
hatchet_honda's Avatar
pretty sure it operates the same way on a dx as an si..just on an si harness the wire colors are in diff locations. sensor is the same
Old Jan 2, 2010 | 02:58 PM
BiG ChOr!Zo's Avatar
The dual point tps and any other tps are different. If you have the d15 dual point you have a completely different tps than any other honda. You would need to find the same exact one. Now there is 2 things you can do.
A-replace whole throttle body with tps already on it (easier, no calibration needed)
B-dremel lines into the fake screws on the tps and unscrew then with a flat head and replace tps and recalibrate it.
Old Jan 2, 2010 | 05:07 PM
beansandrice's Avatar
At exactly 5min Dr. Charles (witch head) Madrid shows you how to set the correct Ohm's on the TPS. .500-.900
Easy!
http://www.youtube.com/watch?v=ukPoe5E4Fqg
Old Jan 3, 2010 | 01:30 AM
CanadianEF9's Avatar
I have 2 dpfi complete intake monifolds if u want a part, for the right price it can be urs.
Asaf
13
Mar 16, 2017 05:32 AM
[S]niper[W]olf
May 19, 2015 06:06 AM
KidFrost
14
Feb 16, 2011 07:43 AM
RippSpeed
Jul 27, 2009 06:51 PM
jose310
Jan 6, 2009 04:19 PM
