EF Hatch Starting issues. OBD0 to OBD1 Conv. w/P28 .....Help????
Old Jan 1, 2010 | 06:40 PM
FSS13foxtrot's Avatar
Default EF Hatch Starting issues. OBD0 to OBD1 Conv. w/P28 .....Help????
89 Si EF9
JDM Single cam Vtec ZC
ZC sohc vtec dizzy.(same as z6) Plugs were changed out to obd1 on harness for dizzy
obd1 injectors (injector plugs changed to OBD 1)
Resistor box plug was cut and i twisted them toger and soldered them. so no resistor box.
P28 ECU Virgin
Jumper Harness(tried this harness for obd0 to obd1 , and another one from Rywire and still no start. i know for certain the rywire harness was for mpfi...
Checked grounds, valve cover, trans. and thermostat.
battery terminals are fine
there is a check engine light after initial attempt to start. can i jumper the plug to read codes even though i am using a jumper harness?
the starter cranks and there is fiel in the rail..
car sometimes will crank after 3 to four attempts
Yes i put oil in it.....
battery is not drained after long periods at rest.
all lighting is at normal brghtness
I would post pics but i am not good with pic stuff.... how do i post them up??
Any help or ideas would be appreciated.
Old Jan 1, 2010 | 07:45 PM
35r'DHyBriD's Avatar
Default Re: EF Hatch Starting issues. OBD0 to OBD1 Conv. w/P28 .....Help????
check all fuses
- check main relay
- add a ground
- try obd0 ecu if it starts it will be in limp mode
- check firing order
just go over your work if everything is correct it may be the motor harness
- was it a DPFI to MPFI conversion first ?
What code is it throwing ?
Old Jan 1, 2010 | 09:35 PM
good call, that reminded me of a couple things...i dont believe it is the main relay because the car was starting fine with the stock engine in it. the 89 si came with mpfi so i had no need to convert, i am going to go check some things. update soon
Old Jan 1, 2010 | 10:56 PM
firing order was wrong but still nothing. same thing with starting as in sometimes turning and most of the time not.....battery is still good
Old Jan 2, 2010 | 12:13 AM
placid888's Avatar
is the starter good? check battery terminals, manually jump a ground from battery negative to engine or trans, then jump another ground from battery negative to body ground, try that and see what happen.
Old Jan 2, 2010 | 09:47 AM
still nothing. thanks for input guys, keep it coming
Old Jan 2, 2010 | 10:11 AM
ZumCRX1's Avatar
DBL an Triple check the Dizzy plugs, I was having the same issue with my first obd1 b swap, I had one wire wrong, also make sure there "clicked into place". You may have created a short by twisting the resister box wiring together and soldering it.
ZumCRX1
Old Jan 2, 2010 | 12:05 PM
I went large white to yel.grn wire and small white to white.... all other colors match up, i will triple check though, and the test light will come out as well. update soon.
Old Jan 2, 2010 | 10:18 PM
still no start. i triple checked the electrical..... fuses are all good, both in bay and in car.
Old Jan 3, 2010 | 02:34 AM
90_DXhatch's Avatar
TRIAL USER
who did the swap harness
Old Jan 7, 2010 | 11:04 AM
I converted the injectors and dizzy... The jumper harness was bought off CL, unknown brand. Well looks like to RYWIRE for answers
Old Sep 20, 2010 | 05:06 PM
ef9 si zc vtech's Avatar
I got the same problem!! anyone have any idea what the problem might be??
i have a soch zc vtech swapped into my 91 ef si and got a p28 chipped by neptune..
im running an obd0-obd1 jumper by h&a import and i have spark but it wont fire up??
if i plug my obd0 ecu in it will fire up with one click?? but its stock on limp mode and i cant pass 3k rpm?? i bypassed the resitor box 2 and im running obd1 dizzy but nothing?
been trying 2 figure dis out for the longest time..
Old Sep 20, 2010 | 10:48 PM
nitewolf's Avatar
probably your jumper harness. i just finished my obd1 conversion the other day. my harness wireing all messed up... https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d-i-y-faq-obd-0-obd-1-pinouts-conversion-help-1319235/ this got my conversion fixed
Old Sep 21, 2010 | 07:41 AM
89civicsiowner's Avatar
ZumCRX1
how are you supposed to removde the resistor box i also just twisted them together and soldered and now im not getting fuel or spark but im pretty sure i have a faulty dizzy so that takes care of the spark
Old Sep 21, 2010 | 08:28 AM
FranklinWalker's Avatar
have you solved it?
Old Sep 23, 2010 | 12:30 AM
yeah bro i rewired it but still nothing?? any other options??thanks 4 the help
Old Feb 24, 2011 | 09:24 PM
90 ef vtec's Avatar
hey did u get it running ??
Old Feb 9, 2012 | 10:44 AM
SdefSedan's Avatar
Hey bro, im kinda late, but did u get it running? I have exacttly the same problem, everything similar to urs
Old Feb 13, 2012 | 09:02 PM
Stunna MIKE's Avatar
All the wires match up but the large white to yellow/green
90civicstdgold
Jul 7, 2011 03:20 PM
dc5itracer
10
Mar 26, 2011 10:29 AM
smokeyjpn221
Apr 21, 2010 06:29 PM
e12ikktos
Aug 26, 2009 03:00 PM
md88hfcrx
Jun 6, 2007 07:12 PM
