89 crx Ground points?
Im sorry if this question is stupid and may have been asked before already.
but i need to know all of my cars ground points because the car wont start.
i think it may be the ground wires.
please any help would be appreciated...pictures would be great.
again, sorry for the stupid question
there is one under the dash left drivers side by the main relay.
Is there spark?
turning over?
getting gas?
check battery and ecu fuse?
ecu light blink when you turn power on?
Is there spark?
turning over?
getting gas?
well aperantly my battery drained..but i dont know why...now everytime i jump it..it wont charge up. and i really dont think it may be the batterybecause its semi new...and the alternator shoudnt be it
That is easy to check. Uncap the battery and check the fluid level. If it is low you should use deionized water to fill up.
charge battery and fire it up.
get your voltimeter and check for correct current from the alternator gold prong (has a 10mm bolt securing the chargine wire.) I think it should be 14v
Sounds like the alternator to me if you don't have a volt meter you can take off the alternator and bring it to a parts store they should be able to check your alternator and battery for free.
hope this helps good luck
R-81DC2
Jun 5, 2007 09:21 AM
flatblack-h22
Apr 3, 2006 08:30 AM
