obd2 to obd1 conversion in eg hatch
Old Jan 1, 2010 | 08:16 AM
beginmyhonda's Avatar
Default obd2 to obd1 conversion in eg hatch
this is for a gsr swap in a eg hatch
i have heard that doing the conversion to obd1 you will need obd1 ecu, injectors, and distributor if i am right?
the only problem is i believe i have an obd2 engine harness, obd2 distributor and injectors. running with a jumper harness to obd1 p72 ecu.
i have no check engine lights though and my car runs fine
so im lost there haha
Old Jan 1, 2010 | 08:21 AM
92ehatch's Avatar
Default Re: obd2 to obd1 conversion in eg hatch
im not too knowledgeable on this subject however i might throw some insight here.
your vehicle is already obd1
you have an obd1 ecu
but an obd2 dizzy and wiring harness.
i didnt think the obd2 wiring harness would work with an obd1 ecu ( i might be wrong)
did you do the swap? if not the other person may have rewired it already to work
Old Jan 1, 2010 | 08:22 AM
RACEPAK's Avatar
why would you have a obd2 harness in a obd1 car?
how many connectors does the distributor have?
also. what color are the injector clips?
Old Jan 1, 2010 | 08:23 AM
BigAnteg's Avatar
u can use all ur ob2 stuff harness and everthing the plug will plug all up im running a 98 gsr in my eg but ur going to need a obd1 ecu either p28 or p72
Old Jan 1, 2010 | 10:29 AM
my cuz already had it in his hatch so we just swap it over to my car
i had no idea on the harness i just helped him bolt it all up
one plug for dizzy and i think black
thats what im running
i am running p72
Old Jan 1, 2010 | 11:03 AM
94EG8's Avatar
Seagull Management
You can use the OBD2 Injectors distributor and alternator so long as you use a '96 - '01 Integra engine harness. The Integra harness is a direct plugin at the shock towers. You then simply use an OBD1 ECU. From the sounds of it this is what you have now.
Old Jan 1, 2010 | 11:54 AM
YES! so its okay then right?
Old Jan 1, 2010 | 11:59 AM
94EG8's Avatar
Seagull Management
Correct.
Old Jan 11, 2010 | 05:02 PM
dohc4life's Avatar
what about in an ef converted to obd1 can you still use an obd2 dizzy? i have a y8 with a chipped p28 ecu and obd2 dizzy
novaslean
Apr 14, 2010 09:23 AM
white2draccord
Nov 10, 2008 08:15 PM
N hatch
Jul 14, 2004 09:52 PM
wade
Jan 23, 2004 10:01 AM
inline4
15
Sep 9, 2003 03:03 PM
