How Would a jackson blower lose boost?
Old Sep 3, 2002 | 05:58 PM
LOwrestling2001's Avatar
Default How Would a jackson blower lose boost?
hi
i am runnin a SCed GSR, and at dynoday, at about 5-6k my boost went past 10 psi into like 11-12...and at 7-8k it tapered off to eventually like 5 psi at 9....anyone know why? before, when i had my car tuned (i had messed w FP settings in between, but i dont see why that would affect boost), boost was consistent 9-10 all the way to 8500...i'm running a 9 psi stepper on my car with hondata and 440 injectors. what gives?
Old Sep 3, 2002 | 06:57 PM
hypa's Avatar
Default Re: How Would a jackson blower lose boost? (LOwrestling2001)
I'd say you have a boost leak somewhere in your IM, or vacuum lines. At least that was the cause of my boost loss problem. Check your intake manifold nuts and bolts to make sure they're solid.
good luck.....
Old Sep 3, 2002 | 09:20 PM
Default Re: How Would a jackson blower lose boost? (hypa)
u think it's that or belts?
Old Sep 3, 2002 | 10:29 PM
vtecdc2's Avatar
yea.. i saw that run.. must have sucked seeing your car lose power...
Old Sep 3, 2002 | 10:41 PM
whtrice01gsr's Avatar
just give me the blower and that'll solve your problem hehe
Old Sep 3, 2002 | 11:16 PM
Default Re: How Would a jackson blower lose boost? (whtrice01gsr)
lol u guys are funny haha...well...the boost tapering off is consistent thru all gears...at around the same rpm...so is it belts or manifold leak?
Old Sep 4, 2002 | 05:58 AM
metal-x's Avatar
where you leaning out?
Old Sep 4, 2002 | 07:23 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: How Would a jackson blower lose boost? (metal-x)
He's running rich!
Old Sep 4, 2002 | 07:30 AM
Rory Breaker's Avatar
Sounds like belts to me...did you check them?
Specifically your alternator belt.
Old Sep 4, 2002 | 07:38 AM
redintegra's Avatar
Default Re: How Would a jackson blower lose boost? (newgsrdriver)
I had just this problem. I would lose boost after 5000rpm to redline. Check your crank - alternator belt tension. That was the one for me.
good luck
Old Sep 4, 2002 | 08:07 AM
Also, if it was a leak, you would be getting a bouncy idle.
Old Sep 4, 2002 | 10:01 AM
how bouncy?
Old Sep 4, 2002 | 10:40 AM
kenji's Avatar
25 Year Member
Sounds like your belt may be slipping an not allowing the supercharger to spin as fast as it could. Going to a smaller pulley for higher boost does not help and is most likely the cause.
If this is the case, try using a larger crank pulley (CR-V) and a slightly larger blower pulley. This will allow you to keep the 10 psi you are looking for and will help to prevent the belt from slipping (more contact area between the blower pulley and belt).
-kenji
Old Sep 4, 2002 | 10:54 AM
hypa's Avatar
not necessarily.
If you had a small leak, you would hardly notice anything at vacuum. My guage didn't even read a vacuum leak. However when the boost kicked in, it would blow right through the are it leaked, and caused my loss. I lost about 3 psi after 5000 rpm to redline.
bads2k
Jun 8, 2011 05:32 AM
aalb1
Nov 15, 2005 02:09 PM
LOwrestling2001
Sep 5, 2002 03:25 AM
