Who's running a moroso oil pan? b series
Old Sep 3, 2002 | 05:29 PM
Tbone's Avatar
Default Who's running a moroso oil pan? b series
Do you notice any oil pressure changes when turning or braking?
Old Sep 4, 2002 | 05:05 AM
Tbone's Avatar
Default Re: Who's running a moroso oil pan? b series (Tbone)
Am I the only one who has one????
Old Sep 4, 2002 | 06:41 AM
LTB420's Avatar
I have a friend with one on a 91 integra but i haven't noticed any oil pressure changes.
Old Sep 4, 2002 | 12:46 PM
hatchy's Avatar
I have one... but haven't installed the oil pressure sender yet..
Old Sep 4, 2002 | 12:59 PM
The_Head's Avatar
My old car had one. I never noticed any changes when turning or braking.
Old Sep 4, 2002 | 01:00 PM
sgT's Avatar
sgT
on my car, the oil has to be topped off or else on left turns and hard braking
i will lose oil pressure. same with my friend's
Old Sep 4, 2002 | 01:32 PM
2point6's Avatar
Default Re: Who's running a moroso oil pan? b series (sgT)
Don't they have internal baffles designed to keep the oil from moving away from the pick up?
Old Sep 4, 2002 | 01:34 PM
MikeSarr_GSR's Avatar
Default Re: Who's running a moroso oil pan? b series (2point6)
more marketing ploys to get your money
sgT's Avatar
sgT
yes, however the pickup has a lot of surface area unlike the stock one which just
has a small slit to draw oil through.
Old Sep 4, 2002 | 01:35 PM
thats at leat a +
Old Sep 4, 2002 | 01:44 PM
sgT's Avatar
sgT
Default Re: Who's running a moroso oil pan? b series (MikeSarr_GSR)
thats at leat a +
but that is a cause of the problem
Old Sep 4, 2002 | 03:36 PM
Tbone's Avatar
Steve, you and I are running the same pan so i figured you would have the same problems as me. I want to see if people running the standard pan are experiencing the same.
when you change yor oil and filter, how many does it take you to top off?
Old Sep 4, 2002 | 03:48 PM
hatchy's Avatar
On my b18c1, with the moroso pan, 5 qts is low, 5.5 to 5.75qts is full. I've ran 6+ qts before and didn't have any problems.
Don Jefe
Nov 8, 2012 03:39 AM
si90rex
Jun 1, 2006 07:22 AM
Takashi1978
Feb 23, 2006 06:21 AM
streetrage
Dec 30, 2005 08:27 PM
RemerLex11
May 15, 2005 02:35 PM
