CEL 23 knock sensor
Old Dec 30, 2009 | 08:58 PM
B18c3_ek00's Avatar
Default CEL 23 knock sensor
was driving around today and all of a sudden CEL came on and i checked it and it was CEL23. how the hell do you tell if the sensor is good or bad? also, where is it located on d16y8? any help will be appreciated
Old Dec 30, 2009 | 09:41 PM
hard_boiled_EG's Avatar
Default Re: CEL 23 knock sensor
if it's not on the headers then it's on the cat
borrow a friends o2 sensor and if the cel goes away that's how u tell if it's bad
Old Dec 30, 2009 | 09:47 PM
itsnotfast's Avatar
The knock sensor is located on the back of the block just above the oil filter, and it requires a 27mm deep socket or wrench to remove it. As far as checking it I don't know. I have the same code and a buddy had a known good knock sensor laying around and gave it to me. I'm waiting for my next oil change to replace it because it looks like it will be a whole lot easier to change with the oil filter off. I believe to buy one they are over $100 so you have the right idea to test it first.
Old Dec 31, 2009 | 11:33 AM
B18c3_ek00's Avatar
thanks for letting me know the location, but does anyone know how to test to see if it is bad or not?
normc
Aug 11, 2009 05:11 AM
oranginal
Jul 6, 2006 02:17 PM
The-LS
Mar 31, 2005 11:19 PM
shadykit
18
Mar 14, 2005 12:51 PM
CM-R
Mar 29, 2002 12:34 AM
