Gas Mileage.
Old Dec 30, 2009 | 07:09 PM
Archangl's Avatar
Default Gas Mileage.
I have a '94 civic ex with an obd2 b18b1, virgin obd1 p75 ecu, intake, exhaust (2.25 inch piping with bobo muffler) and si tranny which is giving me about 17-18 mpg (170 miles per tank) on a good drive (a little spirited). I previously had an ls vtec with a virgin p28, ls tranny, intake and exhaust (stock muffler, 2.25 inch piping) and on a good drive (a little spirited) i would get about 240 miles per tank. I don't know why such a horrible drop in gas mileage.
Old Dec 30, 2009 | 07:25 PM
92shade's Avatar
Default Re: Gas Mileage.
when was the last time u gave it a real good tune up? also, any cels?
Old Dec 30, 2009 | 07:51 PM
Archangl's Avatar
I changed spark plugs about a month ago, but still have the same fuel filter (which is not clogged), the same cap, internals and spark plugs wires (from obd1 dizzy).
Archangl's Avatar
Oh yeah no cel
Old Dec 30, 2009 | 08:39 PM
itsnotfast's Avatar
Every Integra I have ever owned has gotten between 28-33mpg (obviously all B series). I have had 5, maybe 6 Integras.
Old Dec 30, 2009 | 08:43 PM
green99civic's Avatar
Well may have a gas leak somewhere?, the 2.25 piping makes you loose a little bit in gas mileage, and if you say it has a tuned pcm it probably have the car running really rich do you smell gas?, is your exhaust pipe covered in black?
Old Dec 30, 2009 | 08:45 PM
Archangl's Avatar
No only the inside of the muffler. I don't smell gas either.
Old Dec 30, 2009 | 08:48 PM
It could be that used pcm thats been tuned giving you that horrible gas mileage, or id try doing a basic tune up plugs, wires, air filter, check your tire pressures too that changes your gas mileage!
Archangl's Avatar
I don't even know where to begin looking for the gas leak either. The fuel rail and the pressure regulator are all dry.
Old Dec 30, 2009 | 08:51 PM
simply the gas lines that run underneath your car and your gas tank!, the lines get really rusty depending on where you live or the car has lived part of its life
Old Dec 30, 2009 | 08:55 PM
itsnotfast's Avatar
I would say if it is a leak, and it's not the rail or regulator the problem is more than likely going to be the connections at the tank. They usually go bad before the lines do.
Old Dec 30, 2009 | 08:57 PM
Archangl's Avatar
The problem is something that did not happen gradually. It happened since I put the engine in.
Old Dec 30, 2009 | 09:01 PM
Must be the Fuel Delivery or the PCM then
Old Dec 31, 2009 | 09:57 AM
scuzz's Avatar
I've had a 93 CX hatch running B18B1 with 2.5" exhaust system for about a year, and I get around 25-27 mpg around town every tank.
I wind it good through the gears most every red light also.
If you have a leak in engine comp, you'll see or smell.
Mine has new timing belt, valve adj, new plugs, cap, rotor from a year ago.
Good tuneup makes bunches of diff.
roflcopterdown
Dec 31, 2007 12:09 PM
MeekalLS
Jul 1, 2006 06:57 PM
urquidezj
69
Sep 28, 2004 02:25 PM
silverEH2
Apr 7, 2003 08:47 AM
thashadow
Jun 22, 2002 05:39 PM
