Upper Control Arm Stud
Old Dec 30, 2009 | 07:03 PM
88h22_CRX's Avatar
Default Upper Control Arm Stud
1988 CRX
I took the front suspension apart to replace the axles and do a extended wheel stud swap. I was putting everything back together and the driver side UCA stud moves when I try and tighten it.
Does that mean the UCA bushing is bad (its a Blox piece) and I need to replace it or is there a way to keep it from spinning. I dont think I cant fit a pair of vise-grips in there to hold it.
Any tips or tricks would be greatly appreciated.
Old Dec 30, 2009 | 07:24 PM
D16SiHatch's Avatar
Default Re: Upper Control Arm Stud
if its spinning, it's bad. try tightening it with an impact, but definitely get it replaced soon.
Old Dec 30, 2009 | 07:29 PM
88h22_CRX's Avatar
Thanks. Although its an aftermaket unit, is it still possible to buy a new bushing(?) without buying a new UCA?
Old Dec 30, 2009 | 09:09 PM
D16SiHatch's Avatar
the bushings or the ball joint? i cant recall ever seeing a balljoint being sold seperate from the uca. the rubber bushings can be ordered seperate but since it's an aftermarket uca i don't know if the bushing would be different then what the stock uca would use. i imagine not, but i dunno for sure.
Old Dec 30, 2009 | 10:40 PM
~sp33~'s Avatar
EFB055
You could ask the manufacture if they would sell the bushing separate, but i've only ever seen the UCA sold as one piece.
Old Dec 30, 2009 | 11:11 PM
Tyson's Avatar
what?? are you talking about the balljoint or the UCA anchor to the chassis that points up into the engine bay?
if its the balljoint, you just need a new OEM castle nut, or rethread the old nut. the balljoint is worn and the threads get mangled, causing more friction that over comes the balljoint. a dirty way of doing the job is to zap it with an impact wrench if you have it handy. but i would rethread the nut. its probably m10x1.25
if you mean the anchor of the UCA, then theres NO way it should be spinning unless the bolt itself is completely sheared off and you can just lift whats left of it out. if you need to repalce that, just replace it with a junkyard piece. youd have to buy a complete control arm set from honda to get just that piece.
Old Dec 31, 2009 | 06:50 AM
88h22_CRX's Avatar
Sorry for the confusion. All the manuals call it a UCA Ball joint. Its not where the UCA bolts to the chassis its where it bolts onto the piece coming from the wheel hub.
Ill get new nuts to seee if that fixes it. I know I probably need new ones (bushings) because the rubber piece is lose from the metal. I just need to get it moving for now.
Old Dec 31, 2009 | 09:17 AM
BrayzieEF9's Avatar
Lmao to fix this problem you just put a wooden block on top of the uca and put a jack under your lca and jack it up until there's a good amount of pressure on both ends and you will be able to tighten the castle nut.had the same problem when installing uca camber kit
Old Dec 31, 2009 | 09:24 AM
88h22_CRX's Avatar
I never would have thought of that but that makes perfect sense. Im definetly going to do that with the addition of a new castle nut.
What would we do without forums...
Old Dec 31, 2009 | 09:41 AM
BrayzieEF9's Avatar
And what would we do without the common diy-er brain booster known as BEER!!! Haha
akos512
Apr 14, 2019 09:38 AM
justBrowsing
Honda Civic (2001 - 2005)
Jan 30, 2012 12:07 PM
Basilias
Jan 7, 2010 10:45 PM
chatham
May 20, 2006 10:18 PM
CuttingEdge SI
Suspension & Brakes
Jan 27, 2005 04:50 AM
