Engine Swap Help(EG9 B16A engine into EK2 1.3 Auto)
Hi ht members,
planning to do this swap(b16a into EK2 1.3 auto) next year when i got the engine. A few questions i would like to ask. What are the parts that i need? I know I will need alot of parts cause my chasis is from an EK. Pls advise. Thanks.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
https://honda-tech.com/forums/hybrid-engine-swaps-18/faq-detailed-b-series-swap-into-5th-gen-civic-how-check-out-help-everyone-else-too-131949/
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
But the infos are mostly about engine spec and how to swap only. I need to know the parts require for the swap. BTW, mine is a RHD.
Anyone ever did this swap before.?
Motor
Axles
ECU
harness
Depending on what year motor you get you will need a harness
Mounts
Shift linkage
Obvious things like tranny, dizzy, alternator, etc. that your motor might not come with when you buy it.
If you read the how to you can get what you need from that. Use your head a little man. Is your '1.3' a d series?
Motor
Axles
ECU
harness
Mounts
Shift linkage
Motor
Axles
ECU
harness
Mounts
Shift linkage
I might be doing same thing as you but i have a honda civic dx 1997 with d16y7
and its a automatic but i have all the stuff to convert it to a manual
i have
manual trans
clutch kit
clutch pedal
brake pedal
i forgot what the rest of the stuff i got is called
i think i just need a ecu now
and i am going to wait until the summer to do the conversion because i will have more time.
atfer i do the manual conversion, i'm going to get use to driving stick and everything and then start saving to get a b18c1
i have
manual trans
clutch kit
clutch pedal
brake pedal
civickid32
Aug 31, 2004 01:41 PM
