what kind of turbo do i have?
Old Dec 30, 2009 | 05:12 PM
sh!ft's Avatar
Who the fack changed my title?!
Default what kind of turbo do i have?
i just picked up this turbo, and the guy who sold it to me said it was an e50. what ever that means, any ways there are some markings on it and some part numbers that lead me to(obviously) believe that its a turbonetics. i called my local turbo shop(turbochargers.com) and they said by the description i gave them, that it was a pre 2007 turbo and since it was a pre 07, that it might not have the chance of having alot f parts avaliable for it. i dont even know what the specs are for it and im kind of interested to find out what kind it is. its a lil dirty but im going to clean it in a few minutes and see what else i come up with. heres some pics
Old Dec 30, 2009 | 05:24 PM
omg_miiiike's Avatar
Default Re: what kind of turbo do i have?
Looks like a T3/T04E 50 trim Turbonetics to me, I think most all or atleast the new Turbonetics have their name or atleast the 'T' on the compressor housing.. The one I had on my car was a piece of ****, hopefully yours isn't the same way.
Old Dec 30, 2009 | 05:30 PM
sh!ft's Avatar
so what are the specs
Old Dec 30, 2009 | 05:36 PM
sh!ft's Avatar
is it possible to upgrade the wheels and the housings or am i stuck with what i got?
Old Dec 30, 2009 | 05:39 PM
Honestly I don't want to mislead you, I am just telling you what trim etc that looks like to me. It's hard to say whether that wheel was upgraded or not already, the guy couldn't tell you anymore about it? It's weird because there are two different part numbers for the housing and the wheel.
20357 comes back to a .48 A/R turbine housing..
I wouldnt buy a turbo without knowing the specs and you'd have to open this one up and measure the wheels to find the trims.
Old Dec 30, 2009 | 05:46 PM
sh!ft's Avatar
well let me go grab a tape measure and check the wheels
Old Dec 30, 2009 | 05:48 PM
Sell that **** and buy a new turbo that you know wtf it is
That could also be an ebay turbo with a polished housing
Old Dec 30, 2009 | 06:01 PM
sh!ft's Avatar
heres what i measured, the exhaust might be a lil off
intake
center:2-1/8th's
outer:3"
exhaust: 2-9/16th's
but why would it have just the "T" on the exhaust housing then?
Old Dec 30, 2009 | 06:12 PM
intake
center:2-1/8th's
outer:3"
exhaust: 2-9/16th's
Some companies put **** together that way, Garret internals are often found in eBay turbos.
Old Dec 30, 2009 | 06:21 PM
TheShodan's Avatar
Moderator
99.9% those "garrett internals" are only garrett measurements to meet some of their specifications, but they are not Garrett/Honeywell internal components
Old Dec 30, 2009 | 07:04 PM
sh!ft's Avatar
i measured the inlet and its at 2" the center piece is 2 9/16th's and exhaust is 2" as well
im just gonna take it to turbochargers tomorrow and have them take a crack at it. the turbo parts/bolts n nuts are currently soaking in degreaser.
and do you have to use an impact to take the intake nut off? it's a 3/8th's nut
Old Dec 30, 2009 | 07:44 PM
Garbage either way IMO, the Turbonetics I had kept blowing seals but I've never used Garrett; just heard stories.
For the intake nut, I don't recall ever having to use an impact to get it off. Is it that tough by hand?
Old Dec 31, 2009 | 12:09 PM
sh!ft's Avatar
ok so i took the turbo to the shop, they said it was good(for a change) and then took it to turbochargers.com and they also said it was good(no surprise there) and the exhaust is a .63 and intake is a .50 which is cool. it has the stage 3 setup on the exhaust side and an upgraded wheel(i think) on the intake side. the guy said this is the PERFECT turbo for a street lsv-t and it should be kicking out a stout 400 to 500 ponies with no problems at all. he also said i should hit boost around 3300 rpm which is also nice to hear
Old Dec 31, 2009 | 12:12 PM
Good deal, you shouldn't have any problems; you'll have fun with your setup. I miss my LS/V turbo.
Old Dec 31, 2009 | 01:16 PM
912's Avatar
912
man so risky buyin turbo all took apart you got lucky i guess
Old Dec 31, 2009 | 02:01 PM
sh!ft's Avatar
it was a complete turbo. i took it apart and took the pictures when it was taken apart so people could get a better idea of that it looked like inside and out
Old Jan 2, 2010 | 11:39 PM
crvek9's Avatar
id say a .63 57
Old Jan 2, 2010 | 11:47 PM
pi Ka chuuu's Avatar
turbonetics? im an all motor guy sorry if im wrong
Old Jan 2, 2010 | 11:49 PM
crvek9's Avatar
yea its deff. turbonetics
Old Jan 3, 2010 | 06:33 PM
sh!ft's Avatar
How can you tell besides the obvious "T" on the exhaust side?
Old Jan 3, 2010 | 07:17 PM
ATYPR's Avatar
I've had that same turbonetics turbo on my DD for the last 5 years running 17psi without any problems but I have an oil restrictor on mine.
Old Jan 3, 2010 | 10:19 PM
sh!ft's Avatar
That's great to hear! I'm excited to see how mine works out. Have you ever had to rebuild it at all?? And what makes you use a restrictor on it?
Old Jan 4, 2010 | 06:00 PM
ATYPR's Avatar
It came with a restrictor/filter in the feed location so I used it. I've changed the intercooler and a few other things but I haven't touched the turbo since I put it on 5 years ago.
ComposiMo
Oct 15, 2003 09:41 PM
b18cTurbo
May 6, 2003 01:37 PM
dangerzone
Aug 15, 2002 10:37 PM
bigTom
Jul 5, 2001 07:27 PM
