distributor problem.. i think
Old Dec 30, 2009 | 09:05 AM
d serious's Avatar
New User
Default distributor problem.. i think
hey what's up,
so i did a z6/b7 mini-me swap in my 94 sedan. i didn't have a z6 distributor so just for start up purposes. i used the b7 distributor unbolted. car fired up without even a single rotation. i ran it for a sec, then turned it off. needless to say the b7 distributor wasn't staying in place so i took it out to burr the holes. when i was taking it out plugged in the distributor arced off on the head. so i continued to burring the holes to fit for now. when i got done i put it back on. and nothing. sounds like no fire...so i pull the wires and check for spark.. it has a very weak fire. so my first thought is that i messed up the coil when it arched off. got a new coil. tried it still nothing.. so i bought a used z6 distributor off ebay, because i needed one anyway. installed it, still nothing.. tried another p06. still nothing. i can't help but think that i just need to buy a new distributor because the one i bought was really corroded when i opened it up like it had been exposed to salt water. any suggestions? and when i call the parts store they tell me they need some part code because they say there are two different ones?
thanks alot
Old Jan 3, 2010 | 01:12 PM
d serious's Avatar
New User
Default Re: distributor problem.. i think
did i post this in the wrong section?
Old Jan 6, 2010 | 02:23 PM
boostedblkef's Avatar
Wow my eyes hurt... but anyway check power at the the dizzy?
Old Jan 6, 2010 | 02:58 PM
fasthatch95's Avatar
did u chek your battery fuse & ecu fuse! u said you sparked it right?
Old Jan 6, 2010 | 11:24 PM
d serious's Avatar
New User
yes i checked the ecu and battery fuse. it does spark but just barely. when it turns over it kinda acts like the timing is off. i reset the timing to make sure it wasn't 180 out. correct me if i'm wrong, but seing as how the cam is notched to where it'll only go on one way it would be impossible for it to be 180 out?
Old Jan 7, 2010 | 05:25 AM
keep in post will figure it all out, anywayz pull your 12mm bolt from ur cam sprocket. just cuz there notched don t matter. Ive had these nothes crack right off before a few times therefore da cam sprocket slipz and turns itz own way in circles. the other day my si did this also! guess what it was! my rotor inside the dizzy & cap well the plastic rotor got hot and cracked off & then wen i pulled my cap, my rotor fell out in pieces.This is why my timming felt funny.
Old Jan 7, 2010 | 05:30 AM
by the way is ur fuel pump even turning, cuz u got spark dizzy componentz should be fine! but still look at that rotor and inspect ur cap anywayz juz to b sure.
Old Jan 7, 2010 | 06:07 PM
d serious's Avatar
New User
yeah i definitely have fuel. i forgot to tigten up the fuel line when i first put it back together and it sprayed fuel all over the place. when i turn it over it spins a few times then backfires. the spark is really weak. it ran fine before i took the distributor off to drill it out. that's what made me think it's something in the ignition, or the timing possibly
Old Jan 7, 2010 | 06:08 PM
d serious's Avatar
New User
thanks alot btw
Old Jan 8, 2010 | 10:03 AM
could be ur coil , cuz ICMs go out u get no spark , Also do u have the litte coil spring between your cap and ign coil , and make sure ur wires r right too.
DRAGANDB1
Aug 9, 2018 06:19 PM
Jhicks
Jan 28, 2012 07:08 PM
jdmkidd23
11
Nov 17, 2008 08:54 AM
thunderboy
Jan 7, 2008 05:51 AM
movingIIshadow
May 17, 2006 09:28 PM
