Turbo d16y7...no idle acelerates after 4k need help
Old Dec 30, 2009 | 05:09 AM
jay-d-em's Avatar
Default Turbo d16y7...no idle acelerates after 4k need help
I have a 00 civic hatch with a d16y7 turbo. Car always ran great,no major problems beside replacing the dizzy and broken map sensor wire. Last night I was letting the car warm up before I left work(as usual)and went I left the parking lot car running fine. I got on it alittle and when I came to a stop sign down the street from my job, the car shut off. Now it doesn't want to stay idle and it idles ruff when I hold the gas pedal. But after 4k rpm it sounds fine. I need help!!! I thought. Maybe it hit boost creep cuz of the cold weather but I let it sit last night and still sounds the same. Something had to happen from when I left my job to the stop sign which was only one block of driving.
Old Jan 20, 2010 | 04:34 PM
jay-d-em's Avatar
Default Re: Turbo d16y7...no idle acelerates after 4k need help
problem found and fixed. map sensor wire broken
Old Jan 23, 2010 | 02:22 AM
Sic_DA_Nine's Avatar
started to happen to me right now
I have a turbo d16y7 and suddenly when its cold, it idles funny.
when I hit the gas and let off, the rpm drops and dies out.
when I hold onto the gas pedal a bit, the idle slightly surges up and down but once warm, it drives perfect.
was the broken wire visible?or did u have to use a multimeter to test it?any info on how and why it happened?
Old Jan 23, 2010 | 08:43 AM
HiProfile's Avatar
As listed in sooo many other posts, surging idle is usually caused from a vacuum leak. Did you set your idle via factory procedure? You disconnect the IACV, move set screw on TB to 400rpm idle, turn off & reset ecu. If you can't idle down to 400rpm, you have a vac leak.
bigpunn421
Mar 21, 2012 03:14 PM
4tika4
Apr 19, 2009 09:43 AM
jaydoghondacivic25
Jan 29, 2006 07:55 AM
ECICivic
12
Mar 4, 2005 07:15 PM
groundedcivic91
14
Feb 8, 2005 07:14 PM
