Am i screwed?
Old Dec 29, 2009 | 11:25 AM
mane793's Avatar
Icon3 Am i screwed?
does anyone know what the problem is? i took off the valve cover and everything looked good so maybe its the block? its making this noise like metal is hitting all around and theres oil dripping. heres a video: http://qik.com/video/4180227
thanks a lot for your help, I appreciate it.
Old Dec 29, 2009 | 11:27 AM
CivicSpoon's Avatar
Default Re: Am i screwed?
Kind of hard to tell from the video (you can never get good sound out of them), but it sounds like rod knock to me.
Old Dec 29, 2009 | 11:38 AM
hannslebo's Avatar
im with SPOON. I had a 300zx NA and broke a rod and sounded very similar
Old Dec 29, 2009 | 11:44 AM
94CivicSi's Avatar
I agree on rod knock.
What do the plugs look like? Like something's been hitting one of them? Or maybe the electrode has broken off one? If not, it's going to be something loose inside the crankcase.
On the plus side, you can probably get another non-VTEC d series longblock for next to nothing.
Old Dec 29, 2009 | 12:23 PM
mane793's Avatar
the plugs look fine. i just want to know if its worth fixing or not. someone just e-mailed me about a d for 200 so thats not bad. its just at a bad location(ghetto) and idk if it will be a reliable engine. im looking for an ls or singlecam vtec because i have around 1200$
Old Dec 29, 2009 | 12:26 PM
bigweedy's Avatar
rod knock! get a zc for that car
viva the SOHC!
Old Dec 29, 2009 | 12:34 PM
egvtec's Avatar
Time to swap engines or blocks. car-part.com should get u a nice sohc if u cant find one locally, theres also the jdm importers. D15b would be prob 700 shipped
94CivicSi's Avatar
Call around to a few wrecking yards. They'll usually give you a 30 or 60 day warranty if you're concerned about the health of the motor.
If you're going to upgrade, go with the LS. My 2000 EX has had SOHC VTEC and DOHC non-VTEC motors in it and I've been MUCH happier with the latter, especially for a daily.
mane793's Avatar
viva the SOHC!
yeah im thinking about getting a sohc and boosting it in the future. but the thing is,...its IMPOSSIBLE to find one right now and idk why. i could find these all day before
Old Dec 29, 2009 | 12:37 PM
mane793's Avatar
id love to get an ls, but cant find that locally either. hopefully i get an email about an ls swap. how much do they run for a swap do you think? and cant you use the same mounts? what would i need for a complete swap into my delsol? thanks in advance
Old Dec 29, 2009 | 12:38 PM
egvtec's Avatar
Why not order one from naganojapanese.com or some other importer?
Old Dec 29, 2009 | 12:42 PM
mane793's Avatar
i would but i dont have a lot of cash right now and im going to need extra $ to pay some one to install it. thanks though, i'll check out that site
Old Dec 29, 2009 | 12:59 PM
got00rice's Avatar
hey sound like mine...but mine is the waterpump that went out tho. check that.
Old Dec 29, 2009 | 01:13 PM
egvtec's Avatar
Good Luck
Old Dec 29, 2009 | 01:44 PM
mane793's Avatar
Good Luck
thanks, if anything happens this week, i'll post up
Old Dec 29, 2009 | 06:10 PM
accord2civic2prelude's Avatar
try checking your valve lash first. most ppl overlooked that and automatically suspect rod knock. check the clearance on those cause a bad valve lash will sound like a rod knock if left unfixed.
Old Dec 29, 2009 | 06:27 PM
b18cKoupe's Avatar
put a proper title on your threads so other people can use the search button and help themselves.
Old Dec 29, 2009 | 06:32 PM
jalepanos22's Avatar
Loose bottom end due to low oil or bad oil pump. Source out for another engine.
leem23vtec
Nov 4, 2010 04:34 PM
preludeboybmw
Sep 29, 2010 04:21 PM
jdmboy96
18
Apr 25, 2009 11:16 AM
92b16si
15
May 1, 2007 07:08 AM
hatchback_al
13
Apr 25, 2004 09:29 PM
