B16a swap in 99 integra gs
Old Dec 28, 2009 | 06:33 PM
vadimqwe's Avatar
Default B16a swap in 99 integra gs
My friend has a 99 integra gs with b16a swap and we cant figure out why vtec doesnt engage. He got the car with the swap already. It has B16a stamped on the block with pr3-1 head and td84 dizzy. It is running on p72a02 ecu. It has a few tapped wires running to vteck solenoid. We cant figure out which ecu we need. The car looks like obd2 and everything is connected meaning it starts and runs but vtec doesnt engage. What ecu do we need to run?
Thanks for all the help
Old Dec 28, 2009 | 06:36 PM
Brice.Hayden's Avatar
Default Re: B16a swap in 99 integra gs
what rpms does it rev to? does it make pass 6k?
Old Dec 28, 2009 | 09:29 PM
vadimqwe's Avatar
i think it does but i will check tomorrow
thanks
Old Dec 29, 2009 | 05:48 AM
vtec should hit in a gsr around 4500-4700 rpms, since it doesn't have the IABs that the GSR intake manifold, nothing will happen at 6000. I assume you've driven to at least 5000 rpms.
Old Dec 29, 2009 | 07:59 AM
vadimqwe's Avatar
so what is the solution? Do i need obd2 to obd1 jumper harness with chipped p28 ecu? What map for chipped p28?
thanks for helping
Old Dec 29, 2009 | 08:39 AM
DJYoshaBYD's Avatar
i just dont think that vtec is wired right.. look in the FAQs on how to wire up vtec to the ecu, and start checking wires
Old Dec 29, 2009 | 11:49 AM
freakin_eLRoD's Avatar
b16a swap with a p72 ecu? is it throwing any codes? if its a stock obd2b p72, then its probably looking for the secondaries on the intake manifold, among a few things. If everything is obd2b, try running the p2t ecu from the 99-00 civic si, or get and obd2-obd1 jumper harness with a p30 ecu or chipped p28 and call it a day.
kingofyo1
37
Sep 28, 2011 07:01 AM
b16adc2
Jun 1, 2009 03:01 AM
dickdragon
Oct 11, 2007 12:08 AM
Jenbo831
Dec 8, 2004 08:13 PM
Eg6_JDM
May 9, 2002 11:34 AM
