MPFI Rail question?
I have everything I need to swap over to MPFI minus a fuel rail and injectors. I have a b18a1 fuel rail and injectors though. Would it be possible to use these injectors and this rail or do I absolutely need the matching a6 rail and injectors.
This will all be giong in my d15b2 crx obd0
Thanks!
Thanks!
Thanks!
Thanks!
Agree with the above posters. If they are obd0 b18a injectors then its MPFI as normal (with si fuel rail), if they are 92-93 obd1 b18a injectors then you'll notice the injector clips won't plug in properly, and you'll need to eliminate the resistor box and get obd1 injector plugs, or modify the obd0 plugs if possible.
the.hamburglar
Jul 14, 2007 12:01 PM
