D15B8/D15B Vtec Head timing belt help
Old Dec 27, 2009 | 11:08 PM
aznflipboi08's Avatar
Default D15B8/D15B Vtec Head timing belt help
I tried the Z6 timing belt with this combo and it was too loose so I tried the Z1 timing belt and it fitted on perfect with no problems.. But the problem is that whenever i put the crank and cam to TDC, I try to put the timing belt over the cam but the crank shaft keeps moving and gets out of time.. How can I prevent the crank from moving when sliding the belt over?
Old Dec 27, 2009 | 11:24 PM
thumper64's Avatar
Default Re: D15B8/D15B Vtec Head timing belt help
Have someone hold the crank? There should be enough compression to keep the motor from spinning. Loosen the timing belt tensioner and you should be able to slide the belt on.
delsolboi
Mar 13, 2013 11:57 AM
Rost
Jul 3, 2009 09:51 PM
hitvtecgetloud09
Mar 21, 2004 05:27 PM
akkord94
Sep 21, 2003 06:58 PM
made in JAPAN
Feb 6, 2003 07:30 AM
