Low idle, no power, CEL 9, b20/vtec chipped
Old Dec 27, 2009 | 02:08 PM
ali954's Avatar
Default Low idle, no power, CEL 9, b20/vtec chipped
So i have a 94' del sol with a b20b4 block and 91' b16 head. its running off a chipped p06 running a "b20/vtec base map" by Ramey Built. The car idles very low to the point of stalling out regularly sometimes and if i turn on the AC it stalls everytime. Its throwing CEL 9
Things ive done to try to fix:
cleaned out IACV - I have one to replace it guna try that
replaced the CYP sensor - had spare guts so i replaced it -going to adjust gap
Old Dec 27, 2009 | 04:39 PM
freakasis's Avatar
Default Re: Low idle, no power, CEL 9, b20/vtec chipped
yeah, replace the sensor in the dizzy. but check the wiring first, since its easier. be sure to check under the pattery tray. ive seen loose trays cut the harness a few times, and the cyp sensor wires seen to be right on top in the OEM harness.
Old Dec 28, 2009 | 08:47 AM
Justin4's Avatar
are you sure the sensor you replaced it with is good? have you tried changing the distributor with a known working one?
Old Dec 28, 2009 | 12:30 PM
ali954's Avatar
next thing im goin to do when u have time is bust out the multimeter and test wires and make sure all sensors have the right resistance
sOLLEx
Apr 11, 2014 05:39 PM
B20vtec veteran
Jun 25, 2013 08:46 AM
zx2gotboost
Apr 22, 2011 01:42 PM
95GSRDC2
Sep 5, 2007 02:39 PM
MI4$DC5
Apr 11, 2007 10:07 AM
