adjust idle - TPS???
I have a problem with a IDLE. When I put on the TPS 0.45, 0.5 then idling is not stable, every 15 seconds, it increases slightly, about 50 RPM, then sharply dropped to ~ 750 RPM. IF I put TPS 0.65 then idling is stable .'ll show how to configure?
ps: idling I put on manual
engine is F22B DOHC'96
ecu is P39-N50
car is Accord'94 CD3
and if set fuel pressure on 4kg - idle is perfectly
ecu is P39-N50
