stock ek running rich and bogs
Old Dec 26, 2009 | 03:15 PM
1sikhatch's Avatar
Default stock ek running rich and bogs
i have a completely stock ek hatch with a gsr fuel pump dat i had lying around because my hatch didnt have fuel pmp when i bought it.
the problem im havig is that if the car sits with the ac on for a few minutes itslike the motor is flooded with gas it would move really slow and if i full throttle it, it bogs.
can the fuel pump be the reason its doin this? i have no cel either
Old Dec 26, 2009 | 11:39 PM
Arthas's Avatar
Default Re: stock ek running rich and bogs
In for the answer. Ive heard of people running different fuel pumps without a problem..
Old Dec 27, 2009 | 03:35 PM
1sikhatch's Avatar
nobody can help me out here?
Old Dec 27, 2009 | 04:15 PM
Linked's Avatar
check fuel pressure, could be fuel pump or fuel filter
check oxygen sensor, it can still run a bit rich without throwing a cel
Old Dec 28, 2009 | 08:21 PM
1sikhatch's Avatar
fuel pressure and filter is good for sure, and the pump came out of a working gsr, i've been trying to find a stock single cam fuel pump and i cant believe its so hard to get one
how do i check the oxygen sensor?
Old Dec 31, 2009 | 12:20 AM
Linked's Avatar
take out the oxygen sensor, im not sure on the color but AFAIK
grey color tip = normal operation
black means its fouled with carbon and will make car run rich
there were some other colors but i cant remember
what engine do you have so you can locate the exact position of your o2 sensor
Old Dec 31, 2009 | 01:34 AM
dr0b0t_13's Avatar
The O2 sensor is on a couple of places #1 on the down pipe close to the headers or #2 near the down pipe closer the the cat/test pipe . If it was your O2 Sensor it'd throw a cel in a heartbeat I've had this happen to me multiple occasions. It really sounds like a fuel pump to me. I would troubleshoot at the fuel pump and work from there. Im not tryin to be a smartass but maybe the pump is just bad. you can get a walbro for like 100 plus tax. whats your engine size?
Old Dec 31, 2009 | 02:11 AM
1sikhatch's Avatar
i have the stock d16y7, and the o2 sensors look fine
Devious951
Sep 12, 2009 04:54 PM
Import_2
Oct 23, 2008 08:35 PM
bluesi00
Sep 7, 2004 10:20 PM
SPEEDQUEST INC.
Apr 28, 2004 10:39 AM
alky350
May 1, 2003 06:00 AM
