t1 catch can fitting
Old Dec 25, 2009 | 03:54 PM
1sikhatch's Avatar
Default t1 catch can fitting
i bought a t1 catch can without the lines or fitting so can someone tell me where i can get all the fittings and lines so i can put in my catch can. if there is a place or someone who sells a complete kit dat woud be better
i also need the fitting dat go in the back of the block
mine uses 6an
Old Dec 25, 2009 | 07:46 PM
Turbo-LS's Avatar
Default Re: t1 catch can fitting
Why didnt you just buy it with everything? its gogin to cost you about the same to piece it together.
www.summitracing.com is your friend here. or B&R fittings can be found on here .
I would just return the can and buy it with everything personally, its painless and its all there
Old Dec 25, 2009 | 07:53 PM
NonovUrbizniz's Avatar
Loved
Contact t1 or B R Fittings.
Either place will price out all the fittings and lines for you...
But like mentioned above you'd probobly save money by just buying it all together...
There's more profit for them to play with in the catchcan that they produce as opposed to the fittings/hose which are 3rd party produced.
Old Dec 25, 2009 | 08:31 PM
jdm inc's Avatar
Contact T1 he should have the fittings and lines.
Agree with buying it all together to save money.
http://t1raceparts.com/en/products/d...-complete.html
Old Dec 26, 2009 | 11:12 PM
thumper64's Avatar
You don't need AN fittings on a catch can, unless you're going for looks, and those anodized AN fittings sure do look nice...
Jegs and other places including eBay have AN fittings.
Old Dec 27, 2009 | 10:22 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
support our sponsors, that's why they pay to advertise what they have and you ususally get a h-t hookup
T1 oe BnR in no particular order. I personally have B&R cause i was looking for a certian look
Old Dec 27, 2009 | 10:26 AM
dpetro1's Avatar
www.anplumbing.com also carries a full line of earl's fittings.
Old Dec 27, 2009 | 12:07 PM
OregonGrown's Avatar
if i had to do it all over again i would have just done the push style an fittings and black hose. Probably would have saved half if not more.
Old Dec 27, 2009 | 03:34 PM
1sikhatch's Avatar
when i bought the can it was suposed to come with the fittings but the guy said he ran out and was gonna order sum. sure enough i never got them and if i depend on him i'll never get them
ill check out the sponsors and the other links, thanks guys
Old Dec 27, 2009 | 03:36 PM
single slam 12's Avatar
BINGO you are absolutely rite function before form. you can buy push locks for 5 bux in brass and black nylon line isnt too expensive seen it cheap on ebay a few times.
Old Dec 27, 2009 | 04:54 PM
B R Fittings's Avatar
You do not want to use the black nylon line with push lock fittings. Its only meant to be used with the AN hose ends.
The rubber on the inside will crack. If you use the barbed fittings use push lock hose only.
Old Dec 28, 2009 | 10:11 AM
dpetro1's Avatar
mine uses 6an
what exactly are you looking for here? does the can have two -6 drains to the back of the block? -10 or -12 is more common for drains. but i think the b&r front block port fitting might work if you need -6. seen at the top of this thread https://honda-tech.com/forums/forced-induction-49/turbo-coolant-line-kits-w-black-fittings-2014711/
dE.fUsEd
Nov 9, 2011 08:13 PM
Turbo_y8
Jan 19, 2006 10:17 AM
krazy
Jul 9, 2003 11:47 PM
ridnmyhonda
Jan 25, 2003 10:38 PM
rOby
Nov 14, 2002 08:42 PM
