What crank Damper/pulley to use?
Old Dec 25, 2009 | 08:34 AM
turbo boost's Avatar
Default What crank Damper/pulley to use?
My power goal is 480-500whp and im just wondering what damper/pulley to use? and were is a good spot to buy one?
or is stock B series pulley fine for this whp?
thanks
Old Dec 25, 2009 | 08:51 AM
sanman000719's Avatar
Default Re: What crank Damper/pulley to use?
IM AT 574 ON A STOCK PULLY
Old Dec 25, 2009 | 12:42 PM
aldagod's Avatar
stock
Old Dec 25, 2009 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
anyone read the rulebook for nhra tracks? you need an sfi balancer: general rule section
1.2 ENGINE
all classes with the exception of stock and et cars slower than 10.99 seconds, harmonic balancer meeting SFI Spec 18.1 or solid metallic hub manditory. all cars with pressed on front harmonic balancers must have such installed as to protect against accidental loss.
with that said, either way id rather have an ati or fluidamper because they are better anyway.
i have been using a fluidamper street damper for 4 years strong now,
Old Dec 25, 2009 | 03:09 PM
i have hardly ever seen anyone running anything other than stock, and even though they are pressed on they still have a bolt that presses them on as well as secures them
Old Dec 25, 2009 | 04:08 PM
Mr. Badwrench
any engine spinning higher than designed will benefit from a harmonic balancer. but if you guys trust a stock one to not come flying apart at one point, thats fine.
Old Dec 25, 2009 | 06:00 PM
TheShodan's Avatar
Moderator
Never had a problem here on the stock at over 9500rpms for 12 years. Unless the rules of the events that you plan to participate in require it as a "tech" requirement, stock works fine for that hp level.
Old Dec 25, 2009 | 06:34 PM
Mr. Badwrench
i guess the reason im stressin, is yes nhra requires it, and after seeing the carnage of big daddys clutch explosion, if i am going to be spinning it hard, id like to see it the SFI says it should hold up hahaa.
and i will agree with stock as long as no one posts yeah my N1 pulley is the cats ***. hahaa.
Old Dec 25, 2009 | 07:49 PM
Turbo-LS's Avatar
ATI street or stock. Im runngin stock no issues but obviously the ati or fluidamper are going to work much better than the oem
ati works better and better the higher you rev vs the fluidamper works better down lower initially off the start and then decreases with rpms but still better than a oem
Old Dec 26, 2009 | 06:25 AM
ok well i think ill stick with the oem pulley for now then...thanks guys
kornerk12
Feb 9, 2007 11:54 AM
crumb
Oct 31, 2005 09:41 AM
[tk4L] Doke
Oct 28, 2003 06:39 PM
DB8
Apr 12, 2003 04:41 PM
